fuel injector?
Old Oct 31, 2009 | 03:28 PM
88PONY's Avatar
88PONY
fuel injector?
how can you tell if you have a bad injector?
Old Oct 31, 2009 | 03:32 PM
JFlom77's Avatar
JFlom77
it will cause a misfire, should throw a CEL telling what cylinder isnt firining
Old Oct 31, 2009 | 03:44 PM
88PONY's Avatar
88PONY
well i just changed the head gasket. it was popped between cyl#1 and #2 i had code p0301. and now after the job the light came on again and i still have the same code p0301. trucks got plenty of power i dont get it. it has 200k in it.
Old Oct 31, 2009 | 05:21 PM
Conanski's Avatar
Conanski
Take a look at the plug on #1, if it's white and the other cylinders are tan like they should be then the injector is dirty or failing.
Old Oct 31, 2009 | 05:29 PM
88PONY's Avatar
88PONY
ok i might have to drive it around for a bit cause its got new plugs. as i said i just did a head gasket on it and have only drove it about 5miles.
akblackfoot
Jul 29, 2017 05:58 PM
gary gauger
May 16, 2017 06:35 PM
genscripter
May 23, 2016 09:28 PM
jmuenchow
Oct 13, 2015 08:14 PM
tdpower
19
Feb 1, 2009 11:05 AM
