Injector stiction??
Old Sep 9, 2011 | 10:32 PM
Jessef250's Avatar
Jessef250
Injector stiction??
How can you tell if the injectors are stiking or not?
Old Sep 9, 2011 | 11:07 PM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
Engine will not idle/run well when started cold...like when left overnight. What are your trucks symptoms?
Old Sep 10, 2011 | 02:37 AM
Jessef250's Avatar
Jessef250
Misses, runs rough for first 10-15 miles, warms up runs fine
Old Sep 10, 2011 | 08:36 AM
69cj's Avatar
69cj
You also need to check your ficm. Hope all filters and oil changes are up to date also with OEM filters.
Old Sep 10, 2011 | 11:42 AM
73stang's Avatar
73stang
Are you getting white smoke on cold starts? Does it smell like diesel fuel?
Old Sep 10, 2011 | 03:15 PM
Dieselpop's Avatar
Dieselpop
What 69cj said , it sounds like the ficm need to load test your batteries or if they are old get some new one because weak or bad batteries will kill the ficm. Check it
Ford 6.0 FICM Testing & Removal Instructional Video - YouTube
pop
Old Sep 10, 2011 | 04:06 PM
utahtom's Avatar
utahtom
Stiction symptoms are typically defined as: Engine runs rough and seems to miss fire during the first few minutes of driving when the engine is cold or has not yet reached operating temperature- Then runs great when the engine is warm. My injector test is not what they do at the dealer... but gives a person a simple, relatively quick and good idea whether or not the engine issue is probably stiction related.
If you are consistantly experiencing stiction like symptoms when your engine is cold: Plug in the block heater overnight or for at least 3-4 hours before leaving your home in the morning (even in the summer). If your engine runs great with no usual rough running or missing during the first few minutes of driving, you probably have stiction- JMO
Old Sep 10, 2011 | 09:14 PM
Jessef250's Avatar
Jessef250
Just recently bought the truck 10k ago. Previous owner did not take care of fuel system. Within 2 days of owning,I found the secondary furl filter black and sucked together. I had to replace fuel pump, Fuel filters, oil change (oem filters), icp sensor and connector, #1 injector, fuel pressure regulator and thermostat. 3 weeks ago replaced both batteries and alternator. Ficm has 48 volts when cranking. Starts has white smoke, and misses bad. When warm runs better but not typical 6.0.
What is the fix for stiction? Replace all 8 injectors?
Old Sep 10, 2011 | 09:15 PM
Jessef250's Avatar
Jessef250
And utahtom tonite I'm plugging her in and will findout in am results.. Thanks for the suggestion!!
Old Sep 10, 2011 | 11:32 PM
zhilton's Avatar
zhilton
I believe the last couple of flashes "buzz the coils" on start up to help warm the oil in the spoil valves. I know my '08 vintage flash buzzes 'em every time you turn the key to on when your waiting for the glow plug light to go out. So my suggestion would be...if your spoil valves don't buzz on start up...get the truck re-flashed.
Old Sep 11, 2011 | 07:55 AM
Jessef250's Avatar
Jessef250
Unplugged truck this morning. Started and ran better, little white smoke (not near as much) still slightly misses.
Old Sep 11, 2011 | 09:00 AM
69cj's Avatar
69cj
You also need a set of gauges to check the ect/eot deltas.
Bill Conner
13
Mar 8, 2012 10:20 PM
fixitman1310
Apr 15, 2010 07:43 PM
Uncle Shank
Dec 17, 2009 04:21 PM
Franko72
88
Jun 16, 2009 12:15 PM
beaboarder
Nov 8, 2003 12:31 AM
