Sponsored by: Real Truck
front blocks
Old Feb 6, 2007 | 01:33 AM
steve604's Avatar
steve604
front blocks
i have a 2000 superduty f250 4x4 and want to do a really cheap lift on it due to the fact that the truck is a bit of a beater at the moment.
can anyone explain to me exactly what problems i might end up with if i just add some 2 or 3" blocks to the front axle? how will this affect my steering?
Old Feb 6, 2007 | 02:12 AM
VQ2Fast4U's Avatar
VQ2Fast4U
Front blocks are a big no no. Just get yourself an add a leaf, or some shackels. It will be about the same price.
Old Feb 6, 2007 | 02:18 AM
hunter101's Avatar
hunter101
I have blocks in the rear, but never in the front. I believe laws are against it anyway and probably for good reason.
Old Feb 6, 2007 | 07:50 AM
HeavyAssault's Avatar
HeavyAssault
Front blocks are illegal in most states due to accidents and drivability concerns.
Old Feb 6, 2007 | 07:55 AM
jake00's Avatar
jake00
cheap like hockey puck cheap, or cheap like 2x4 cheap
Old Feb 6, 2007 | 10:22 AM
steve604's Avatar
steve604
i realise everyone says they are very, very bad and i should feel shame for even mentioning this subject but doesn anyone know what would happen if i was to use them? extreme axle wrap? steering geometry way off?
i know someone that owns a ford truck wrecking business and has a pile of about 100 blocks waiting to be taken.
if i go the route of the add-a-leaf or shackles then how many inches can i go up before i have to start changing steering parts?
Old Feb 6, 2007 | 10:57 AM
heidiandmax's Avatar
heidiandmax
Around 3"s is max as to where you will still be able to use factory parts.Any higher you will need a drop pitman and a lower pan-rod bracket to keep the steering geometry.Also longer sway bar end links plus shocks.
52 and 76
Sep 2, 2013 09:18 AM
precisiontile
Feb 10, 2013 11:22 AM
jmikeyj4
19
Nov 12, 2010 04:54 AM
shore
Dec 13, 2008 10:22 AM
biggreen4x4
May 29, 2003 12:27 AM
