putting pistons in block
Old May 27, 2003 | 09:18 PM
biggreen4x4's Avatar
biggreen4x4
by the end of the week i will be putting the pistons back into my 400 block. i noticed yesterday that the arrows for the 1-4 cylinders were actually pointing toward the back of the block so i pressed them off and put them to where they point toward the front of the block. now i want to be absolutely sure that i have this right. On the drivers side of the block, the arrow will be toward the bottom of the bore but still pointing toward the front. On the passengers side the arrow will be at the top of the bore and again, pointing toward toward the front of the block. Does this sound right?
Old May 27, 2003 | 09:32 PM
cartwright's Avatar
cartwright
What do you mean by top of the bore and bottom of the bore?
Old May 27, 2003 | 09:35 PM
Matts72's Avatar
Matts72
Top of bore = towards the intake
Bottom of bore = topwards the exhaust manifold.
Old May 27, 2003 | 09:42 PM
cartwright's Avatar
cartwright
I mean regarding the arrows on the pistons. They should all point towards the front.
Old May 27, 2003 | 09:48 PM
biggreen4x4
i was thinking that all the arrows would be at the top of the bore pointing towards the front. they will still point towards the front of the block. yet the arrows are not all at the top or toward the bottom of the bore. i can't remember when i tore the engine down if the stock pistons had all the arrows at the top of the bore or not.
Old May 27, 2003 | 09:53 PM
Matts72's Avatar
Matts72
I was curious why you were asking and shook my head a couple times before respoding.
Old May 27, 2003 | 09:54 PM
cartwright's Avatar
cartwright
Hmmmmm, I dont remember what a stock piston looks likes. I suppose as long as you put them back in their original locations and the arrows all point towards the front they should be right.
But I could be wrong.
Old May 27, 2003 | 11:58 PM
kopfenjager's Avatar
kopfenjager
Thumbs up putting pistons in block
I have been told that the numbers on the rod caps correspond to the firing order, but when I pulled my engine apart they where in order from front to back 1-8. The marks on the top of the pistons point to the front of the engine.
Old May 28, 2003 | 02:52 PM
cartwright's Avatar
cartwright
The numbers on the rods are for matching them to their original cylinders, they dont have anything to do with firing order.
Old May 29, 2003 | 12:27 AM
kopfenjager
Wen I pulled my engine apart they where #'rd from front to rear 1-8
1977cj5
Sep 26, 2018 12:28 AM
bama29fan
Jun 20, 2010 10:53 AM
wgm114
Air Intakes, Air Filters & Ram Air
Dec 29, 2007 01:42 PM
lattices2
Exhaust Systems
13
May 9, 2005 07:06 AM
dbc
May 14, 2003 05:23 PM
