need help determining rear u bolt size
Old Feb 9, 2013 | 10:48 PM
precisiontile's Avatar
precisiontile
I have a 2000 4 wheel drive Ex and recently bought a set of Rough Country 4" LIFT BLOCKS. Currently my Ex is stock (springs, 2" blocks , etc). I want to remove the 2" blocks and install the 4". I replaced the front springs and am ok with the rear springs just want to replace the blocks. Can someone chime in on the sizeof the u bolts I am needing?
Old Feb 9, 2013 | 11:24 PM
EXv10's Avatar
EXv10
And the answer is; (drum roll please)....................2" longer U bolts.
Old Feb 9, 2013 | 11:39 PM
hav24wheel's Avatar
hav24wheel
5/8in rod, 3.5 inch tube, and 14 inches long is what I used if I remember right.
Old Feb 10, 2013 | 09:50 AM
Snowseeker's Avatar
Snowseeker
Get to long and cut them off after installing and torquing them down.
Old Feb 10, 2013 | 11:22 AM
housedad's Avatar
housedad
HUSKY SPRING Part # UA207R $10.36 each from Rockauto plus shipping. They include deep wall nuts.
The OEM bolts are 10 1/2". The bolts above are 13 1/2".
Drill down their menu to the Suspension section of your vehicle. Click on "Leaf Spring Bolt" and the options are there.
The 13 !/2" are the standard length for the F350.
For some reason, Rockauto shows the 13 1/2" inch as a option in all the Excursion listings.
jtfisher63
Nov 23, 2015 11:19 PM
wrxin
Jul 18, 2014 12:57 AM
deadeyedevon
1978 - 1996 Big Bronco
29
Apr 10, 2012 11:55 AM
lethalinjection
Mar 30, 2005 09:15 PM
Scoarch
Jan 2, 2004 02:20 AM
