Oil Usage
Old Feb 4, 2007 | 12:25 PM
96f150's Avatar
96f150
Oil Usage
Does anyone check there oil on a normal basis? Say every 1000mi or so? Just checked my oil after changing it 1000mi ago and is is down about 1.5 quarts. I have the 5.4 with only 10k on it. Yeah, I make short trips to work about 10 miles, so I have the milky substance underneath the oil cap, but still 1.5 quarts is a hell of an amount of oil to be consuming. I don't want to start a big thread on this, but if any of you guys are seeing this too, then hell, I'll assume its normal.
Thanks
Rich
Old Feb 4, 2007 | 12:52 PM
GoldenDually's Avatar
GoldenDually
Sounds like it wasn't refilled all the way. Maybe forgot to compensate for the new oil filter?
Old Feb 4, 2007 | 12:56 PM
johntucker09's Avatar
johntucker09
whoever changed the oil might have only put in 6 quarts instead of 7, the 4.6L takes 6 qts (don't start arguing over this) and the 5.4 takes 7...
Old Feb 4, 2007 | 12:58 PM
96f150's Avatar
96f150
I checked it about an hour after I let it cool down from the change, and it was dead on 7qts. This happened on the first change also. Who knows why, guess I'll just keep an eye on it.
Old Feb 4, 2007 | 01:00 PM
johntucker09
run off...you still should have oil in the valvetrain and in the cylinders until it cools down...
Old Feb 4, 2007 | 01:01 PM
johntucker09
I had an old 302 that would had a bad dry-start condition when pulling a cold start, but when it was warm, no problem...
Old Feb 4, 2007 | 01:08 PM
96f150's Avatar
96f150
I would think an hour is plenty time for the oil to drain back down to the pan for an accurate check.
Old Feb 4, 2007 | 01:10 PM
johntucker09
user said that after an hour, it was normal...
Old Feb 4, 2007 | 09:39 PM
ShootinOK's Avatar
ShootinOK
Take it in - 1 quart in an oil change is A LOT of oil.
Mine was doing that at about 25k miles - the dealer found an O ring leaking around the oil filler and replaced it under warranty. I never did see any oil on the driveway or on the motor, but it was going somewhere.
I do check mine about every 1000 miles, call me paranoid, but my truck works pretty hard. I like to take care of it.
Old Feb 4, 2007 | 09:42 PM
96f150's Avatar
96f150
Hmm....An o-ring leaking around the filter.....sounds odd, but hey ya never know
Old Feb 5, 2007 | 08:05 AM
ShootinOK's Avatar
ShootinOK
Not filter -- filler -- filler tube on the valve cover.
EcoboostKev
17
Nov 26, 2014 07:52 PM
someday
Oil & Lubrication
15
Apr 4, 2009 07:18 AM
ARMORER
Jan 10, 2005 05:38 PM
brcowan
Modular V10 (6.8l)
28
Oct 31, 2003 02:20 PM
hokiebob
Jul 16, 2003 03:11 PM
