heater cable problem
Old Feb 3, 2007 | 01:07 AM
jasonmerlo's Avatar
jasonmerlo
Can anyone tell me where the heater cable connects on an 80-86 F-150 with a 300? My (senile) mechanic apparently removed mine and forgot to put it back so I've been without a defroster for 3 yrs and am finally fed up with it. I can see where it connects to the switch itself, but I cannot find where it will connect on the other end. Please help.
Old Feb 3, 2007 | 02:50 PM
88F-150pimp's Avatar
88F-150pimp
I'm going to assume that the heating system is designed similar to '87 to '91 trucks, just because I doubt ford ever changed the design that much between the years. You should try removing the glove box, behind this is where the heater cable connects at the top of the plenum box to a small pivot arm that controls the blend door. I believe it is at the top, but this may be the cable that controls where the heat is put out. If so, then the cable is at the bottom of the plenum in the same kind of setup. Either way, once you have the glovebox off, things should be pretty clear.
dspy8083
Oct 10, 2013 12:58 PM
Kleenax
Oct 24, 2009 08:42 PM
cr9c1
Jan 1, 2007 01:57 PM
gentle1
Feb 6, 2002 11:25 PM
billy21
Jan 31, 2002 12:19 PM
