Ahhh!!!
Old Feb 2, 2007 | 11:40 PM
rztmartini's Avatar
rztmartini
Ahhh!!!
i was drivin all of a sudden i could smell coolant and white smoke started billowing out of the A/C vents and defroster, covering my windshield in steam and coolant started dripping on the floor of the car (passenger side) and outside on the ground. WHAT HAPPENED?!?!
Old Feb 2, 2007 | 11:59 PM
stractor's Avatar
stractor
Time for a new heater core--yours has sprung a leak.
stractor
Old Feb 3, 2007 | 12:00 AM
rztmartini's Avatar
rztmartini
do i get one from auto-parts store? or jy? how hard is it to fix?
Old Feb 3, 2007 | 12:12 AM
stractor's Avatar
stractor
Junk yard or possibly a parts store or on the internet at one of the parts stores. Check a repair manual for removal ,if I remember the core is accessable from outside the cab on the firewall, but it is encased in an enclosure that has to be removed. It is easier if it it is outside that a passenger car that usually has to be removed from inside under the dash, a real pain in the butt--done that.
stractor
Old Feb 3, 2007 | 12:14 AM
rztmartini's Avatar
rztmartini
sweet thanks a lot. for a second i thought i had cracked my head.
Old Feb 3, 2007 | 03:40 PM
1984 300 Project's Avatar
1984 300 Project
You can get a new one from Napa. They are pretty cheap and easy to fix. This is the first thing I fixed when I got my truck and I didn't know much back then. It is accessible from the engine compartment but you might have to also remove some screws from behind the glove compartment. This of course was on an 84.
Old Feb 3, 2007 | 10:42 PM
rztmartini's Avatar
rztmartini
would it be possible to just connect the two water hoses and eliminate the heater alltogether? im in Hawaii so i wont be using it...ever...lol
Old Feb 4, 2007 | 12:22 AM
stractor's Avatar
stractor
Yes-----
stractor
Old Feb 4, 2007 | 01:34 AM
Col Flashman's Avatar
Col Flashman
Huh?
Why on earth would you believe that?
You'd be having something like that coming out your tailpipe, if that were the case, though more than likely you'd not notice it @ all, not into the interior of you cab.
Old Feb 4, 2007 | 11:08 AM
slammercb's Avatar
slammercb
Auto parts stores sell caps the block off the heater inlet and outlet ports. Just slip them over the ports and tighten with hose clamps.
