Heater Temperature Control
Old Oct 24, 2009 | 12:10 PM
Kleenax's Avatar
Kleenax
Went to turn on the defroster this AM and NOTHING! I think the cable broke or something on the center temp-control ****. Before I pulled the dash off or something, can someone steer me to an easier solution as to where the cable connects? I assume it's just one of those push-pull kind of metal-encased cables? Can I get to it under the hood? I couldn't see where it came from OR where it went (raining/blowing like crazy here).
Thanks in advance!
Old Oct 24, 2009 | 05:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Not sure if the 92 heater works the same way or not, but the defrost/heater/vent selector is vacuum operated.
The temp control is a cable to the blend door in the heater box behind the glove box.
Engine coolant circulates through the heater core constantly.
So the blend door regulates the temp by changing where the air is drawn from.
Old Oct 24, 2009 | 05:56 PM
Kleenax's Avatar
Kleenax
Yea, I think they're the same; the controls all look the same anyway. Thanks for the glove box location; that was what I was looking for...
Seems the last one of these that I worked on, that blend door was located in the housing out on the firewall, but I think that was a 58 Ford P/U.
Old Oct 24, 2009 | 08:42 PM
Dave Sponaugle
On mine if I remember right the blend door is to the right of the heater core and can be seen through the opening when you change the heater core.
Remove the glove box door and the box.
That lets you see what you are working on so you can find the 5/16" head bolts that join the two parts of the housing, 4 or 5 from memory.
Something may have fallen down through the defrost vent and have the door jambed, or the hinge could have failed.
Then again it may be something as simple as the control wire slipped off the door arm.
Good luck on your adventure under the dash.
rhoward
Aug 25, 2014 06:38 PM
The Masked Rider
Jul 29, 2013 05:11 AM
bduemig
Apr 20, 2013 09:29 PM
bautz2001
1983 - 2012 Ranger & B-Series
Jul 17, 2012 02:42 AM
billy21
Jan 31, 2002 12:19 PM
