9 inch third member ?
Old Jan 31, 2007 | 08:39 AM
6cougar9's Avatar
6cougar9
I am rebuilding the third member in my 9 inch,its my first time and Im not sure how thick of a shim to use. It had 3.00 gear in it I am switching to 3.89 gears with a detroit tru-track.The old gears do not have any markings on them what should I do? I have been reading the third member rebuild section but alittle confused any help would be appriciated.
Old Jan 31, 2007 | 01:20 PM
andym's Avatar
andym
There's no answer to your question - each carrier and set of gears is different. That's why backlash, pinion depth, and everything else needs to be precisely measured with the right tools. This is also why most people take their gears to a pro to be set up.
Old Jan 31, 2007 | 05:19 PM
6cougar9's Avatar
6cougar9
ok thanks Ill start a mock up with the one that was origionally in there and go from there by adding or subtracting thickness . I guess this is why they say its time consuming.
Old Jan 31, 2007 | 05:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When you buy a R&P from Ford or a supplier, it comes with everything needed to set them up. Shims, grease, gasket, even the powder. It's only time consuming to one who hasn't done many. A good shop can set 6 to 8 a day....per mechanic.
Old Jan 31, 2007 | 05:55 PM
6cougar9's Avatar
6cougar9
I bought a kit, its just my first time setting one up I want to learn but I dont want it to be an expensive lesson.
Old Jan 31, 2007 | 11:12 PM
6cougar9's Avatar
6cougar9
So do I make sure I have the proper gear mesh and if not add or subtract shims?Anyone know
Old Feb 1, 2007 | 12:46 AM
NumberDummy
If you've never done one before..pay someone to do it...or you it may cost you far more $$$ later.
Old Feb 1, 2007 | 02:05 AM
6cougar9's Avatar
6cougar9
I understand but im a do it yourselfer
I built the engine myself and converted it to a manual transmission and all the wiring. now im doing the third member.
If not I have a friend that knows how to set them up I can ask him for soome help but he is hard to get ahold of.
Old Feb 1, 2007 | 01:29 PM
andym's Avatar
andym
You need some expensive and special tools to set up a rear end. If you don't know how to do it, you will get it wrong, I promise. A rear end that's not set up right will self-destruct quickly. Your ring & pinion will definitely be destroyed, and there will be collateral damage as well.
If you don't know how to do this, and from the questions you're asking you clearly don't, then either get in touch with your friend or pay someone to do it.
Old Feb 1, 2007 | 02:08 PM
6cougar9's Avatar
6cougar9
My buddie is coming over tonight
TheProfessorofTOOL
Aug 29, 2016 10:39 AM
mike
1978 - 1996 Big Bronco
Jun 7, 2016 08:09 AM
underthebridgejim
Apr 27, 2015 02:32 PM
tylerbailey1
13
Jan 2, 2013 10:48 PM
Dads 66
Apr 12, 2005 09:31 PM
