Cracked 9" 3rd member
Old Dec 26, 2012 | 04:20 PM
tylerbailey1's Avatar
tylerbailey1
Hey Guys,
I've got a cracked third member housing and I'm looking at getting it replaced with one from a junk yard.
Will any 9" third member housing work? Or do I need to know my bearing size?
1977 F-150 4x4
Old Dec 26, 2012 | 04:32 PM
HIO Silver's Avatar
HIO Silver
Confusion reigns with your terminology
Just call it an 9-inch axle housing.. not a 3rd member which refers to the pumpkin.
No, not any axle housing will work.. spring pads, shock mounts,etc can be different dimensions.. measure/verify perch to perch, OAL, etc...... get a housing out of a Dentside and verify your bearing size to reduce the likelihood of not getting the right one.
Old Dec 26, 2012 | 05:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973 9's use the large ball type axle bearing, as do some 1974/79's. Some 1974/79's 9's have a tapered roller bearing/seal combination.
1974/79: There's no way to know which bearing type it has, an axleshaft has to be pulled to find out.
Old Dec 26, 2012 | 05:58 PM
tylerbailey1
Its the actual third member (pumpkin) that is cracked, not my axle housing. I've got a locker in it that I am planning on keeping and putting in a new one.
I guess what I'm wanting to know is will my ring and pinion swap over without any problems into any new empty pumpkin??
Sorry for the confusion
Old Dec 26, 2012 | 06:11 PM
HIO Silver's Avatar
HIO Silver
Whoa.. exactly the opposite of what I thot you were saying.
A 9-inch carrier is a 9-inch carrier... yes... in the end, it all depends what it is stuffed with (28 vs 31 vs 35 spline internals).
Old Dec 26, 2012 | 06:17 PM
tylerbailey1
OK great! Thats the answer I was hoping for. Thanks.
Old Dec 27, 2012 | 04:16 AM
NumberDummy
No such thing as 35 spline axleshafts in any F100/150 w/a 9 inch. 1957/67 F100: 28 / 1968/72 F100 could be either 28 or 31 (w/a 9 3/8" ring gear) / 1973/83 F100 & 1975/86 F150 could have either 28 or 31.
35 splined axleshafts were used in mid 70's thru 1986 F250 Dana 60 rear axles.
Old Dec 27, 2012 | 09:27 AM
bamaf150's Avatar
bamaf150
Is it true that the 31 spline axles are the ones with the two "dimples" marked in the center of the outboard end?
Old Jan 2, 2013 | 01:09 PM
tylerbailey1
ok, so I've been shopping around for a new carrier and I'm finding some that come in different bearing size/bore diameter. I'm finding some that say they use a 2.89", 3.062", or a 3.25".
I'm planning on taking the gears out of my current cracked carrier and putting them in the replacement. And I can't just pull mine out and measure it.
Am I reading too much into this?
HIO Silver, you say a carrier is a carrier, but when I go to order one I see different options and I'm getting confused.
Sorry for my ignorance on the subject, but I really appreciate your help.
Old Jan 2, 2013 | 02:25 PM
NumberDummy
D7AZ-4141-A .. 9" Carrier Assy-Use with axle ratios from 2.47-1 thru 3.70-1.
1973/83 F100 / 1973/86 Bronco / 1975/86 F150 & E100/150 // 1973 Mustang / 1973/76 Torino/Montego / 1973/78 LTD/Marquis / 1973/79 Cougar/Ranchero/Thunderbird/Continental Mark IV & V.
1975/80 Granada/Monarch/Versailles / 1977/79 LTD II (not an LTD!).
Note: Many of these cars also came with 8 inch rear axles that look very similar to a 9 inch.
Old Jan 2, 2013 | 04:24 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Here is a pic of my 1982, which should have 31 spline axles (I haven't pulled it). I however pulled a third member from another 1982 and it was in-fact 31 spline.
Old Jan 2, 2013 | 09:25 PM
hasteranger's Avatar
hasteranger
best way to know is to pull the axle. you can make a good guess but you won't know for sure until you pull them. And they are pretty easy to pull, its like a 10 min job.
Old Jan 2, 2013 | 10:18 PM
bamaf150's Avatar
bamaf150
Thats the same as mine. In another thread someone said the same thing today; these are the 31 spine axles, I dont know as Ive never had to pull one on the 3 half tons with 9'' I've owned.
Old Jan 2, 2013 | 10:48 PM
hasteranger
I'm pretty sure my 28 spline axles I pulled out of a used 9" housing I changed over to 31 spline were the same though. apparently I didn't take pics of them from that angle but I did take pics from a few other ones.
Danilo
Dec 5, 2010 10:25 AM
1975Ford
15
Nov 21, 2005 11:19 AM
WrenchHead84
Dec 28, 2003 08:27 PM
tetraruby300
Nov 2, 2003 01:29 PM
blaxuede
Mar 28, 2002 10:31 PM
