Third member ID
Old Apr 12, 2005 | 08:16 PM
Dads 66's Avatar
Dads 66
Third member ID
I have a third member laying on the floor and am trying to ID it. Where can i find out what rearend i have. Also how can i determine what the gear ratio is? I count 45 teeth on the ring and 16 on the pinion with a 28 tooth axle spline. I know the gears are ford 9". I would appreciate any information provided.
Old Apr 12, 2005 | 09:31 PM
polcat's Avatar
polcat
I believe you divide 16 into 45 which would give you a 2.81, but not certain on this. it could be dividing it the other way?? if it is all together and can be turned. mark your ring gear and count how many time your yoke turns to the ring gear turning once. hope this helps
mike
1978 - 1996 Big Bronco
Jun 7, 2016 08:09 AM
Dirtscooter250
Dec 5, 2015 09:18 PM
mikewilson85
16
May 17, 2015 02:53 PM
jjurva!
Dec 15, 2012 07:39 PM
6cougar9
Feb 1, 2007 02:08 PM
