I would say yes....but the question is do you trust yourself to do it right, I know I don't. I did the sandblasting myself and went to a place and got them professionally done. Now I know that there won't be any issues in the future with burning headers.
does the 5.4L motor mount get in the way or is that just an issue with the 4.6L?
I would assume it's the same. Not much difference between the two on the outside. BTW, the motor mounts are not in the way, they need to be loosened or completely undone and the motor jacked up to be able to slide one of the headers into place. Doing my '03 F-150 with 4.6L and installing Gibson shorty headers, the studs had to be removed to be able to slide them in place. The oil dipstick tube was removed and had to be hand bent to make it fit after header was in place. I can't see any headers being much easier to install than another. All of the headers are similarly designed and the engine compartments are pretty much the same.
Having the correct tools and following directions, I would think a header job could be done in 8-12 hours. Of course mechanical experience makes a big difference.
I was just outside paining my muffler with Dupli-Color's high temp paint "with ceramic"
but it can't be the same as ceramic coating.
I have a lot of mechanical experience, but the more i see how eaten away the bolts/studs are, the more i think it might be a job for the local shop, if they'll let me buy my own parts.....
I think a little liquid wrench and a wire brush would clean up the studs and nuts. Of course, I put the headers on my truck when I only had 600+ miles. Everything came loose pretty easy. No air tools or hammer required. The sooner you do it, the better. Just hope putting a 4" ProComp suspension lift-kit won't be too hard with 26,000+ miles. I keep the truck clean, so I shouldn't have to worry about bolts being rusted or caked with crap.
I keep mine clean too and store 4-5 months during the winter, UPSTATE NY winters are ROUGH....but with 92k and AT LEAST 2 broken studs (on the same flange too, HOW BAD IS THAT?) I think I might leave it up to the new (very highly rated) garage I'm going to.
If you are lucky, there is a part of the studs sticking out when the exhaust manifold comes off. It would suck to have to drill it out and tap the hole. Not a lot of room to work with. BTW, how the hell do you brake a couple of studs?
I see Summit is selling a set now as well- $149.95 what do you guys think? I was gonna sand blast them and get them ceramic coated as well- heres the specs- they have a set for both the 4.6 and the 5.4-
Material: Steel
Header Finish: Painted
Header Style: Shorty
Primary Tube Diameter (in): 1 1/2 in.
Collector Attachment: Stock flange
Collector Diameter (in): 2.500 in.
Tuned: No
Primary Tube Gauge: 16-gauge
Cylinder Head Port Shape: Oval
Flange Style: Standard
Flange Thickness (in): 3/8 in.
Bolts/Studs Included: Yes
Gaskets Included: Yes
Reducers Included: No
Y-Pipe Included: No
Quantity: Sold as a pair.
Great price, but they are only steel. The stainless steel with ceramic coating go for anywhere from $500-$800. I have no idea if there is much difference between all of them, performance wise. Almost anything is better than the stock exhaust manifolds. I figured for the money and only wanting to do the job once, I had to get stainless. Whether I got chrome, ceramic, or plain stainless depended on what else I was buying. I just didn't want to face rusting down the road.
Hatingchevies.I would buy a better set. Get a good set of headers for truck use. Towing &offroad use is tough on headers. Plus installing a set on a 5.4 is a hard job.I have stainless steel JBAs on my truck. I put them on in 03. I have over 60,000 miles on them.They haven't leaked or given any problems. I've towed a lot with my truck plus I've bracket raced it a good bit. A friend put a cheap set on his F150. He replaced the gaskets several times in less than 1yr. After about 18 months one side cracked at the base plate. Save your money & get a good set is my opinion.
If I was going to put another set of shorty headers on my 5.4 I would use the Bassani. They are 14 guage tubes & come with SS Comp header gaskets. Also included are heat schields for protecting all the wiring. They fit much better than my JBAs. I helped put a set on a 99 F150 after I did my truck & the fit & finish was much better. The bolts more clearance around them & I didn't have to bend the EGR tube to make it fit like I did on the JBAs.
I had to bend the EGR tube with my Gibsons. Also the oil dipstick. It's definitely not a fun job to do. Now that I've done it, it wouldn't be so bad to do it again.
that year is infamous for just rusting and FALLING off....i didn't believe it til i saw it on my own truck....shop quoted me $250-300 with plans for several to snap off.
