Question
Old Jan 19, 2007 | 11:00 AM
inline6 Red Neck's Avatar
inline6 Red Neck
Red face Question
what rear ends came in f150 form 80-96 and how do i tell what gears i have
Old Jan 19, 2007 | 11:46 AM
mantta's Avatar
mantta
Check the axle code on the door sticker or, check the tag attached to the differential. It is usually on one of the bolts for the cover or the pumkin.
Old Jan 19, 2007 | 01:04 PM
Drew2010's Avatar
Drew2010
if you cant read the axle tag then read the door panel sticker
Old Jan 19, 2007 | 04:10 PM
inline6 Red Neck
i got that tag if i go to the junk yard to get a rear end do i just match all the numbers on my tag to junk yard rear end tag
Old Jan 19, 2007 | 04:13 PM
mantta's Avatar
mantta
If you can give me the numbers off of that tag, I can de-code it for you.
Old Jan 19, 2007 | 04:26 PM
inline6 Red Neck
top numers are S838B
bottom numbers are 355 88 3802
i just need to get a rear end from a junk yard i just want to get the right one
with the same gears a such
Old Jan 19, 2007 | 04:36 PM
andym's Avatar
andym
You have an 8.8" axle with 3.55 gears on an open carrier. As long as you get an 8.8" axle from an F-150 or Bronco you'll be alright. Before 1983, all Broncos and F-150's came with a 9" axle, which looks different and isn't available in the same ratios. Close, but probably not what you want. After 86, they all had the 8.8".
Old Jan 19, 2007 | 04:41 PM
mantta's Avatar
mantta
Top Number is S838B S=Sterling Plant, 838B=Plant Code
Bottom Number, 355= 3.55 Ratio, 88=8.8" ring gear diameter
3802 3=year, 8=month, 02= day of manufacture.
Hope this helps you.
Larry Mantta
Old Jan 19, 2007 | 04:46 PM
inline6 Red Neck
3.55 is the only gears the came in the 8.8
Old Jan 19, 2007 | 04:50 PM
mantta's Avatar
mantta
No, not at all, there were the following ratios with the 8.8;
2.73, 3.08, 3.55, 4.10, 3.73.
AJB201
Jul 1, 2012 01:50 PM
GotLift
Mar 3, 2004 02:30 AM
RawPower
Jan 30, 2004 09:31 PM
shakespearesdad
Oct 27, 2002 08:54 PM
