Sponsored by: Auxito
transmission shakes???????
Old Jan 18, 2007 | 07:50 PM
worknon10s's Avatar
worknon10s
my 98 4x4 ext cab 150 has 175k on it, runs great except for the trans just starting shaking..........when im in overdrive and slightly give it gas it will shake, its only when you accelerate, normal driving everything seems fine? what could cause this?
Old Jan 18, 2007 | 08:21 PM
bones318v8's Avatar
bones318v8
could be the mounts or mount,go under and check the mount?
Old Jan 18, 2007 | 08:25 PM
Wilber15's Avatar
Wilber15
Check where the extension housing bolts to the tranny main housing. There is a tsb out where the bolts work themselves lose or actually break off from the torque generated at that point. I had my bro's on the lift last spring here and all but 3 of his bolts had snapped off and fallen out. Of the remaining only 1 was actually somewhat tight still. Check your tranny fluid level also. Check the driveshaft u-joints also.....
BRay09
1983 - 2012 Ranger & B-Series
Apr 5, 2024 11:44 AM
KASFBAR
Nov 20, 2011 08:42 AM
daddy172005
Sep 5, 2010 12:45 AM
skidooin
Apr 6, 2010 03:07 PM
jth731
15
Feb 24, 2006 09:44 AM
