0060 over in speed density
Old Jan 17, 2007 | 08:34 PM
robertbourque's Avatar
robertbourque
i have a 91 e150 with speed density and i want to know how much i can go over without causing too much driviblity problems .cause i plan on going with maf .later .thanks
Old Jan 17, 2007 | 08:56 PM
baddad457's Avatar
baddad457
Overbore will not affect it.
Old Jan 17, 2007 | 09:52 PM
Blurry94's Avatar
Blurry94
Agreed, overboring, itself, shouldn't cause any problems.
Old Jan 17, 2007 | 09:58 PM
robertbourque
ok what about heads
Old Jan 17, 2007 | 10:33 PM
Blurry94's Avatar
Blurry94
Heads and intakes can work as well. The cam is a different story though, speed density is 'vacuum sensitive' so a lopey cam will most likely cause problems.
With an overbore and aftermarket heads, you may encounter a tip-in lean condition, without aftermarket tuning.
Old Jan 17, 2007 | 10:57 PM
robertbourque
ok thanks guys
Old Jan 18, 2007 | 05:58 AM
baddad457's Avatar
baddad457
Ford programmed the SD systems to be 15% rich at WOT, so you can take that into effect as well. Any mods would have to stack up to more than that to cause it to run lean there.
octaneforce
May 9, 2013 10:07 AM
scott9320
Mar 31, 2005 10:36 AM
JAYNESStheGreat
1978 - 1996 Big Bronco
May 26, 2003 12:25 AM
ScottP460
Mar 28, 2003 08:27 PM
Hartwood
Nov 17, 2001 05:36 PM
