1978 - 1996 Big Bronco
Speed density vs. Mass air
Old May 24, 2003 | 06:36 PM
JAYNESStheGreat's Avatar
JAYNESStheGreat
Question Speed density vs. Mass air
How do you tell the difference between speed density and mass air? i.e. - what do they look like?
Old May 24, 2003 | 07:29 PM
mrwizard's Avatar
mrwizard
Mass air vehicles will have a sensor in the air tube that goes from the air filter box to the throttle body, usually close to the air filter end. If there is a sensor with wires running to it in the air tube, it's mass air. No sensor, speed density.
Old May 24, 2003 | 07:34 PM
JAYNESStheGreat
Great! My 95 is mass air! Woo hoo!
Old May 25, 2003 | 10:19 PM
StrauntonBronco's Avatar
StrauntonBronco
Whats the difference???
Old May 25, 2003 | 11:59 PM
mrwizard's Avatar
mrwizard
Speed Density systems rely on sensors that measure intake manifold vacuum (and probably a few others) to regulate fuel/air ratio. Mass Air uses a sensor in the air intake tube that actually measures the amount of air coming in to the engine. SD can get really messed up by doing lots of modifications on your engine that affect vacuum like bigger cams. Mass Air isn't affected by that because it's still measuring actual air flow.
Old May 26, 2003 | 12:25 AM
steve83's Avatar
steve83
Speed/density uses a preset program based on engine specs, truck weight, transmission, and several other criteria to control the engine, using the sensors only to choose which data table to use.
MAF measures all those things all the time to figure out how to run the engine, and that's why it can adapt to bigger changes.
Power of 8
Nov 6, 2012 04:14 PM
bigmacmonday
Aug 31, 2011 07:59 AM
super 6.8
Oct 17, 2005 07:07 PM
gov2mod
Aug 13, 2004 01:21 PM
snowmobilerfreak
Aug 9, 2004 10:23 AM
