will E303 cam work with speed density
Old Mar 28, 2005 | 08:47 PM
scott9320's Avatar
scott9320
hey guys I was wondering if anyone can tell me if the E303 cam will work with the speed density or will it cause problems for the computer.
thanks
Old Mar 29, 2005 | 03:51 AM
Matt95L's Avatar
Matt95L
I've heard of a few people making it work with a mustang speed density computer,but it required a bit of tuning to get the bugs worked out.Personally i'd just get a speed density friendly cam there are plenty of good ones out there.
Old Mar 29, 2005 | 10:12 AM
Kemicalburns's Avatar
Kemicalburns
any cam with a lob seperation of no less then 114* will work. what motor is this going into?
Old Mar 29, 2005 | 04:12 PM
Matt95L's Avatar
Matt95L
Cams with longer duration(over 218/224 @ .050) also have problems and some cams with lobe seperation less than 114* can work.
The Crower 15511,Comp XE264HR-14,NX264HR-14,and XE270HR-14 are some of the "hotter" ones.
Old Mar 30, 2005 | 02:21 PM
TigerDan's Avatar
TigerDan
Crane makes one for a roller motor w/speed density as well, it's Compucam 2020, #444211. RPM range is 1500-5000, duration @.050 is 208/216, lift is .530. I talked to the Crane Tech guys, and they said this is about the only cam they make that will work with S/D. It requires stiffer springs as well, and since the springs Crane recommends are tapered, you have to use their retainers. The spring/retainer/lock set is #44308. -TD
Old Mar 31, 2005 | 05:54 AM
scott9320's Avatar
scott9320
thanks for all the info guys. the cam would be going in 87 mustang LX coupe 5spd. guess I should have given that info in the first post, never even thought about it.
Old Mar 31, 2005 | 08:34 AM
Kemicalburns
for a mustang that is a good cam. but not being mass air might cause some driveability issues
Old Mar 31, 2005 | 10:36 AM
TigerDan's Avatar
TigerDan
Depending on what you want to do with the car (Haul butt/go fast, or better milage/efficiency) you might be better off to convert to Mass Air first, then swap cams at a later date (depending on your budget, of course) Mass Air wiil allow you a lot more flexibility in cam choice, as well as opening the door for other mods. A Mustang is generally a go fast type of car, so the Crane cam I recommended above would not be my first choice. Yeah, I put one in my 5.0, but it's going in a truck. -TD
fordsvt
Mar 15, 2023 10:19 AM
carfan82
17
Apr 8, 2021 11:11 AM
Nally427
Jan 25, 2020 12:50 PM
BigJared
Feb 15, 2013 09:24 PM
BET F150
Jan 14, 2011 10:09 AM
