Have a 68 bronco project and I think it has the original engine but I would like to confirm that. The casting numbers on the block are 0 C5AE-6015E with a smaller 6L8 above. Does the 6L8 mean 68, if so what would the L stand for. I looked at a chart that was posted here a while ago and my numbers are real close but not on the chart exactly THANKS
Thats the chart I went to before so Im sure its a 289 but what about the year, can that be determined from these #'s. Also the 289HP says orange color code at rear of block, does that have anything to do with the O in front of my #. One more thing is the 65AE on my block dosn't have -E after it like the chart but it does end with 6O15E. (O C5AE- 6015E) Thanks again
Your engine is date coded 6L8 which decodes to 6=1966, L=November, 8=8th day of month....so the block was cast on November 8th, 1966 using the C5AE-6015E block revision. FYI, many early 68 model vehicles could have had a late year 66 engine that was completed in 67. The date of the heads will add information as well.
Also a C5AE 6015E HIPO is the same exact block with only add-on parts that made it a HIPO, such as larger Main Caps, Rods with 3/8" rod bolts, larger balancer, etc. You could check the heads for the 'cupped' springs which identify HIPO heads as well.
Hi johndean66 and Welcome to FTE! Please take a moment to check out the Guidelines as they contain important info that you'll need when posting on the site:
If you happen to look at the dates on the above posts, you'll notice that this thread is over three years old...but perhaps someone else can get some use out of your info! Anyhow, welcome aboard, and we'll see you around!
