1982 F-150 need ignition switch picture-wire placement-on column
Old Aug 5, 2015 | 07:07 PM
  #31
#thomas's Avatar
#thomas
Originally Posted by Mil1ion
Starter switch ?
Ignition switch wiring or steering column wiri
ng?
Do you mean like this connector on the column like a 79 ?
or Like this?
This has the correct wiring for a 1984 ford bronco 4.9 liter.
This is a second pic. Of 1984 ford bronco.
Old Aug 5, 2015 | 07:21 PM
  #32
#thomas's Avatar
#thomas
I dont know if anyone is able to help. I pulled the computer out of a 1984 ford bronco. I trying to install a dura spark II ignition system. I cant find wiring harness for my truck. Well i left with having to run wire from scratch. Trying to tie the correct wire to the ignition switch on the steering wheel. So i will start my question. I need to tie in on the run wire and start wire to the coil with the 1.5 resistor tied in on the run. Which is the run and start? The second question the factory tach is broke how can i bypass that on the spark? Well thats it because i dont even know if this will get a response. Lol
Old Jun 3, 2016 | 04:58 PM
  #33
azgunner's Avatar
azgunner
half moon connector
Ok I have a 1984 ford f250, and I was going to replace the turn signal switch, and little did I know that where the connector is, there are 2 half moon type connections, and I yes I am admitting it, I took apart the wrong one, and now I need to know what connector it is so I can replace it, sad thing is some wires came out ok with the tab on it, some not so lucky. PLEASE HELP. I am tired of things breaking and cant afford to keep replacing my mistakes.
Old Jun 13, 2016 | 08:46 AM
  #34
azgunner's Avatar
azgunner
Hey guys, for some reason now I can not see the pics of the connectors you have linked in this thread . There is a curved connector that I am looking for and no it is not the one for the turn signal switch. It has to do with brake lights and what ever else. I did a big boboo and tore apart the wrong connector. Any help to identify what color wires go where in that connector so I can just get rid of the connector and just hard wire it together would be great. thanks, oh and just fyi I am looking for the female side of the connector.
DAV1972
Nov 18, 2017 02:43 PM
Rustyol79
Aug 14, 2017 02:23 PM
k9education
Aftermarket Products
Jul 21, 2016 12:11 PM
artscott61
Apr 13, 2016 02:00 PM
rews2
Mar 9, 2016 12:12 PM
