safety neutral
Old Apr 12, 2016 | 12:57 PM
artscott61's Avatar
artscott61
Veteran: Navy
safety neutral
truck has never had a safety neutral switch on it. I think for everyone's safety I need to put one on.Need some ideas on where you guys have put yours and what style of switch. First it has an ididit column with shift and a FMX transmission. I would imagine that I would wire it through the starter button on the dash.
Old Apr 12, 2016 | 01:10 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I just checked Google and the link Im posting shows that a FMX trans has a neutral safety switch at the shifter, like a C4. How to Troubleshoot Neutral Safety Switches - Mustang Monthly Magazine I hope this helps . Also you might check to see if the colum shifter you bought has a switch built into it, I have a B&M shifter which did, its worth checking anyway. Best of luck.
Old Apr 12, 2016 | 02:06 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
My NSS is on the Lokar shifter. two terminals. One wire goes to the start circuit on the ignition key and the other wire goes to the start terminal on the fender mounted starter relay. Not the big terminal for battery cable or the cable to the starter. Not the wire to the solenoid on the starter, but the smaller start terminal on the relay.
Old Apr 13, 2016 | 07:09 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I used a switch like the following on my FMX and GM column...
1955 1956 1957 1958 1959 Chevy Truck Brake Light Switch USA New | eBay
Old Apr 13, 2016 | 11:49 AM
artscott61's Avatar
artscott61
Veteran: Navy
great north where did you install it ?
Old Apr 13, 2016 | 11:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The only Ford truck with an FMX: 1973/77 F350 with 300 I-6. The NSS was mounted on the steering column.
FMX introduced in 1968 and with this one exception, was only installed in cars.
Old Apr 13, 2016 | 12:09 PM
underthebridgejim
FTE fan
Thanks Bill, it always helps to have all the facts. I hate posting incorrect information.
Old Apr 13, 2016 | 02:00 PM
GreatNorthWoods
I fabricated a bracket and mounted it so that the brake pedal actuates it as you push it down. Sorry I don't have a picture. After you have the switch you will see how it needs to be mounted to work.
mstein86
Dec 28, 2014 02:04 AM
7.3 Enthusiast
May 5, 2010 07:33 PM
uk1050
Jan 31, 2006 04:53 PM
JMarkle
Electrical Systems/Wiring
Mar 20, 2005 07:52 AM
ya sure
1978 - 1996 Big Bronco
Jun 23, 2003 03:48 PM
