I have a couple of scanners and an OBDII module for my palm and LT.
If i need to check the codes i use a scanner, but for diagnostics the LT or palm are a godsent, they both utilize live graphs to monitor the individual sensors and the LT is able to log.
The Elm327 chip is capable of all protocols, incl CAN
I discovered several laptop solutions and have decided to go with one of those because of the monitoring. I have an old laptop I use in the shop, anyway.
So what laptop programs are you guys recommending? I am considering getting one as I have a couple of laptops sitting around and figure I should put them to use. One suggestion has been the AutoTap. Thoughts?
