Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
code scanners
Old Jan 24, 2007 | 07:59 AM
projectSHO89's Avatar
projectSHO89
Actron does offer two models that show both an OBD1 adapter set and a CAN upgrade available. Cost is around $299-399 for the base unit.
If that 93 is a Ford, you really don't need a scan tool except for speed and convenience, a paper clip will do it.
Steve
Old Jan 24, 2007 | 09:25 AM
rpatrick's Avatar
rpatrick
Steve
The 93 is an F-150.
Can you elaborate on teh paper clip technique - or point me to it?
Rob
Old Jan 24, 2007 | 11:55 AM
Nitramjr's Avatar
Nitramjr
Try this link. I asked the same question once.
https://www.ford-trucks.com/forums/4...e-reading.html
Old Jan 25, 2007 | 10:35 AM
aquanaut20's Avatar
aquanaut20
I have a couple of scanners and an OBDII module for my palm and LT.
If i need to check the codes i use a scanner, but for diagnostics the LT or palm are a godsent, they both utilize live graphs to monitor the individual sensors and the LT is able to log.
The Elm327 chip is capable of all protocols, incl CAN
Old Jan 25, 2007 | 12:07 PM
rpatrick's Avatar
rpatrick
I discovered several laptop solutions and have decided to go with one of those because of the monitoring. I have an old laptop I use in the shop, anyway.
Old Jan 25, 2007 | 12:48 PM
aquanaut20's Avatar
aquanaut20
Stay away from ProScan, Gore Research, they wont answer any emails and support is non existant
Old Jan 25, 2007 | 07:22 PM
Ronin007's Avatar
Ronin007
So what laptop programs are you guys recommending? I am considering getting one as I have a couple of laptops sitting around and figure I should put them to use. One suggestion has been the AutoTap. Thoughts?
Old Jan 25, 2007 | 08:19 PM
rpatrick's Avatar
rpatrick
I'm leaning the AutoTap direction unless somebody posts somethign better here in the next week or so...
Old Jan 26, 2007 | 11:03 PM
projectSHO89
I have Alex Peper's setup. Good performance and support. A bit of an obtuse user interface and sparse instructions, though...
Cost was good plus the autor is local to me.
Steve
Old Feb 6, 2007 | 02:02 PM
aquanaut20's Avatar
aquanaut20
When I need to use log/graph and print functions. I use either my
  • Harrison OBScan(propriatory), or
  • OBD2allinone (Elm327) +CAN, .
For quick code scans
  • Inova 3100 (code book) or
  • Autopro E3199+CAN LCD descriptions
jaoneill
Jul 19, 2013 04:14 PM
bryanlindborg600
Jul 8, 2011 09:54 AM
fepowerguy8
General Automotive Discussion
Oct 3, 2010 04:51 AM
Jonest38
Oct 4, 2009 04:13 PM
MONAVIERONJON
Sep 9, 2009 07:06 PM
