Sponsored by: Auxito
Creaking/Squeaking from front end when braking?
Old Jan 11, 2007 | 07:21 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Okay i have been getting some really weird creaking sounds from what sounds to be the front of my truck when braking. Its only for the last 10-15 feet before i stop and also when im not braking to hard. If i get on the brakes hard it goes away. No its not the rotors or pads, i just put brand new on the front and rear. I think the front wheel bearings might be bad, but when i jack up the front end there dosnt seem to be any play in the wheel... im out of ideas or solutions for this problem. Has any body else heard the noise im trying to describe. The squeak does pulse like if it where a warped rotor but im 99 percent sure its not. Any ways hope sombody has some input.
Old Jan 11, 2007 | 09:28 PM
BURNSTOUGHFORD
Any thoughts would be really helpfull to.
Old Jan 12, 2007 | 12:16 AM
Chris 97 F150's Avatar
Chris 97 F150
have u checked ball joints?
Old Jan 12, 2007 | 07:38 AM
BURNSTOUGHFORD
All brand new 20,000 miles ago or even a little less.....
Old Jan 12, 2007 | 04:33 PM
Moore FOMOCO's Avatar
Moore FOMOCO
Shocks?? Try pushing down on the hood/fenders and see if it creaks then.... maybe front bushings??
Old Jan 12, 2007 | 07:54 PM
BURNSTOUGHFORD
nope.... its in the breaks or somthing to do with the wheels.... its a consitant creak..
Old Jan 12, 2007 | 08:05 PM
triton54's Avatar
triton54
cheap pads? they do it every time with minimal dust or wear
Old Jan 12, 2007 | 08:44 PM
BURNSTOUGHFORD
I bought a good set for the front... they were 50 bucks... supposed to be much better than OEM, and eliminate brake dust... there a silicone i think
Old Jan 12, 2007 | 09:22 PM
triton54's Avatar
triton54
try cleaning them out real good with a power washer at the car wash and see if it helps
Old Jan 13, 2007 | 07:08 AM
Moore FOMOCO
Did you bleed them real good after you R/R'd pads/rotors? Spongy pedal? Reinstalled the pad shims? Did it CREAK before/after break job or just after?
Old Jan 13, 2007 | 12:52 PM
Firefighter6484's Avatar
Firefighter6484
Did you put new rotors on? if so did you clean all the oil off of them first. Not doing This will destroy them and the pads.
Or if you kept old rotors, did you have them turned? If not the new pads will not wear right with the rotor and cuase problems.
Old Jan 14, 2007 | 12:31 AM
BURNSTOUGHFORD
Okay... i sanded the rotors with a hight grit sand paper to give them a rough surface and i cleaned them with brake clean before i put them on.... it started doing the squeaking as soon as i put the brakes on and maybe even before but im not sure, and braking wise they are hard and it stops better than it did before i got the truck... so im leaning toward wheel bearings but i have know way of knowing... when i jack the front end up it dosnt have any play in the wheels
Old Jan 14, 2007 | 07:12 AM
Moore FOMOCO
You said you put some good pads on that creates less dust. The factory (OEM) are semi-metallic, I think that is the difference. The silicone pads are vibrating until you get on the binders hard, which stops the creaking-to-a-stop. It sounds like a call you may have to make creaking vs. dust???? Me ... I have to wash my rims monthly. Do you still have your old (metallic) pads? May reinstall them and just ride a day?
Old Jan 14, 2007 | 11:38 AM
BURNSTOUGHFORD
Ya the pads were junk so thats a no go but pads arent expensive so i wouldnt mind buying a set up oem's
Old Jan 17, 2007 | 01:46 PM
01' Super Crew's Avatar
01' Super Crew
You have what sounds like the same noise I just fixed on my truck. Check out the chain of replies to my post back on 1/05/07.
KJR05
Mar 1, 2014 10:36 AM
aetksmith
Jan 31, 2011 09:53 PM
expojoe
Jun 25, 2009 12:45 PM
YellowSled
Dec 16, 2008 10:22 AM
mrl390
Oct 8, 2007 09:57 PM
