creaking/squeaking noise front end
Old Jan 26, 2011 | 08:35 PM
aetksmith's Avatar
aetksmith
Question creaking/squeaking noise front end
There is a loud creaking noise coming from the front end when I go over speed bumps, and now when I break and accelerate. Does anyone know how do to fix this problem? It seem to get worse in cold weather. What is it that is creaking/squeaking?
Old Jan 26, 2011 | 08:39 PM
EXv10's Avatar
EXv10
If it is not the usuall stuff it could be your needle bearings in the hub.
Old Jan 26, 2011 | 08:40 PM
wpnaes's Avatar
wpnaes
https://www.ford-trucks.com/forums/7...t-article.html
It can wait 'till spring if it's too cold to be under the Ex.
Old Jan 31, 2011 | 05:14 PM
m8trix01's Avatar
m8trix01
Creaking
My Ex. has the same noise. My problem is the leaf springs in front are sagging so much that the rear of the spring is rubbing on the frame. Take a look at the rear spring shackle and see if the spring is rubbing on the frame. If not then its probably the sway bar links of even the ball joints could be popping if they are loose. Hope this helps.
Old Jan 31, 2011 | 07:25 PM
Rickx's Avatar
Rickx
Another problem with the X is the body mounts. There is a bolt under the drivers left foot and another under the passengers right foot. I pulled these bolts, put af loor jack under the body (just enough to take the pressure off), pulled the bushings cleaned and lubed the bushings, applied locktite and torqued them back down to get rid of that sound in mine.
Old Jan 31, 2011 | 09:47 PM
1NiceHarley's Avatar
1NiceHarley
I had a noise in the front of ours and the swaybar bushings that attach the bar to the frame was worn out.
Old Jan 31, 2011 | 09:53 PM
Rickx's Avatar
Rickx
Wow, looks like you've got your work cut out for you. What was that, five different sources of the same type of noise.
What do you want to bet we'll all be crawling under the Xs to look at some other problem areas we just heard of.
Thumper19
53
Jun 6, 2022 06:36 PM
mtnxtreme800
2009 - 2014 F150
18
Aug 14, 2015 06:55 AM
KJR05
Mar 1, 2014 10:36 AM
IronMiner
2009 - 2014 F150
Oct 30, 2012 12:22 PM
MoreBoostPlease
Jul 14, 2011 04:10 AM
