Creaking sound while braking.
Old Oct 8, 2007 | 07:19 PM
mrl390's Avatar
mrl390
Ive noticed lately that when I apply the brakes at slow speeds, I hear a creaking kind of sound. I first noticed it when I was going around this one tight turn on my road and thought it was the frame creaking, but friday I was backing out of work and I applied the brakes while going slow on a level surface and I heard the sound. It seems like its coming from the back brakes. The truck is the one in my sig if that helps at all. Any help would be great, Im getting the front rotors turned at the shop down the street (auto hubs are one of the two things that I will not touch, the other is auto transmissions) and I would like to have them fix the problem (if it even is a problem) with the back brakes while they are at it.
Old Oct 8, 2007 | 07:33 PM
JLDickmon's Avatar
JLDickmon
dude, the truck is 15 years old... that's like, 105 in dog years... you'd creak too...
get some PB Blaster and hose down between the ends of the leafs and the eye bushings and see if it changes...
Old Oct 8, 2007 | 08:42 PM
mrl390's Avatar
mrl390
I have tried PB blaster on the bushings. Its pretty much a regular thing. Oil, grease, blaster, ect. I pretty much always have some sort of lubricant on them as well as the bushings for the radius arms. I have never heard a peep from them. Even if they did make noise, its too much of a cooincidence that it happens only when I press on the brakes. If I make a tight turn without the brake pressed, it makes no sound.
Old Oct 8, 2007 | 09:57 PM
JLDickmon's Avatar
JLDickmon
unless the drums are so bellmouthed that the shoes are walking out...
milsuper
Nov 14, 2016 06:34 PM
rangerbait
6.7L Power Stroke Diesel
Oct 12, 2015 09:36 AM
firedaniel
Apr 4, 2015 06:31 PM
KJR05
Mar 1, 2014 10:36 AM
Skandocious
42
Feb 13, 2008 06:48 PM
