Trans temp question
Old Jan 10, 2007 | 03:16 PM
jkh04200's Avatar
jkh04200
Trans temp question
95 PSD
I installed a new down pipe. Old one had insulation, I assume to keep the heat off the tranny. New pipe comes within about a 1/2 of one of the transmission lines. Should I try to use the insulation off the old downpipe to wrap the new one with or not worry about it?
Old Jan 10, 2007 | 05:28 PM
Cuda_jim's Avatar
Cuda_jim
Use the old insulation. My pipe came too close to the tranny line too so I just remolded the old stuff around the new pipe and secured it with Stainless steel safety wire. Other wire will work too but might rust out. It works good, I used an infrared temp gun and not much heat gets past the insulation.
Old Jan 10, 2007 | 08:21 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
I never wrapped mine, actually reading what you did, that is not a bad idea
super 6.8
Modular V10 (6.8l)
Jan 7, 2017 02:56 AM
Ryan Weaver
Mar 8, 2016 04:06 PM
trnjjohn
2004 - 2008 F150
Mar 28, 2011 07:01 PM
OneTon4Fun
Feb 22, 2008 11:16 AM
ponch37300
22
May 15, 2006 11:27 PM
