Help!! Won't Start??!!
Hello All,
I've got a 93' F-150 4.9L that wouldn't start this morning. My wife drove it yesterday and said it ran fine, but when she went to start it this morning, it wouldn't turn over. According to her (I'm at work right now), the dash lights come on, and she can hear one "click", but that's it. I'm hoping it's just a dead battery (she was unsure whether she left the lights on...that's another story!), but I'm miffed that the dash lights would still come on. Any ideas/advice would be greatly appreciated!!
If it is indeed a starter issue, is that a difficult replacement. Kind of a newbie here.
Thanks in advance!!
Thanks in advance!!
Thanks a bunch for the insight, everyone. I really appreciate it. A little bit of an update....
Got home from work, and it started right up. Shut it down. Tried to start it up, and nothing. Well, actually the lights, radio, wipers all worked, but there was just a single "click" from beneath the hood. Did a quick look at the connections and the ground from the negative to the chassis and didn't see anything obvious. Could it still be the battery? I'm kind of at a loss about where to start with the wiring. I was thinking of pulling the starter and the battery and getting them checked out. Ideas??
Thanks again in advance!!
Umm, does that model use the same or similar cable as the '92? The one that splits at the post and one 4/0 goes to the starter relay and the other to the starter? If so, mine let go inside the molded lead clamp at the battery with NO indication of failure. No corrosion, no burning, NOTHING. Identical symptom. Relay would CLICK, Solenoid would THUNK, but no turn. Turned out to be a 'half-bad' cable. Cut the clamp off and replaced with a $2.00 clamp, and bingo, problem solved. This great intuition however did not occur until after I replaced a starter and a perfectly good battery that Advance Auto Parts said was bad, though. '93 model, odds are .....
StephenHenry
04-28-2010 10:04 AM
wolfehunter
11-20-2003 11:52 AM
