clutch adjustment?
Old Jan 7, 2007 | 08:29 PM
84f250460's Avatar
84f250460
clutch adjustment?
just wondering if there was any way to adjust the clutch on a 1984 f150 I-6 3spd OD? it falls halfway to the floor before grabing.. clutch itself seems ok. also has plenty of fluid in the cylinder.
Old Jan 12, 2007 | 12:53 AM
Jim59's Avatar
Jim59
Could it be the clutch pedal itself that travels too much. On my 1984 F250 351 4speed hyd clutch, I have to rebuild where the clutch pedal arm hangs from the cross rod. There is a metal bushing in there that has worn out, and I don't think is available any more. I have to take it apart and mess with it.
Jim
Old Jan 12, 2007 | 01:44 AM
Chiefrider007's Avatar
Chiefrider007
There are actully several plastic bushings that can be purchased at Napa. The one from the clutch push rod to the pedal is known for causing your type problem. Costs around 6/8 bucks too....Just pull the pedal up and down and look to see if there's play in the connection points.
M1kem3
Feb 27, 2015 12:19 PM
coleboy11
May 9, 2014 06:14 PM
jle70
1978 - 1996 Big Bronco
Dec 24, 2013 09:47 PM
Farmer Jay
Oct 23, 2008 06:44 PM
