1978 - 1996 Big Bronco
clutch adjustment
Old Dec 23, 2013 | 02:00 PM
jle70's Avatar
jle70
clutch adjustment
I recently replaced clutch and slave cylinder. I cannot figure out why the clutch pedal is almost all the way out before it starts to engage.
Old Dec 23, 2013 | 07:55 PM
86fsbronco's Avatar
86fsbronco
What kind of slave cylinder is it internal or external? and did you bleed it to the manufacturers specification?
Old Dec 23, 2013 | 08:17 PM
jle70's Avatar
jle70
Internal. Yes, bled correctly.
Old Dec 23, 2013 | 08:53 PM
86fsbronco's Avatar
86fsbronco
There is no adjustment on hydraulic clutch system. Unless you get a new master cylinder that has an adjustable rod but that's only the to make up for slop in the clutch pedal assembly.
If its going all the way to the floor before it disengages the clutch the there is still air in the system when I put a 5 speed in my 86 I just pump the heck out of it once the let it gravity bleed for a minute then pumped it some more an gravity bleed again
Old Dec 23, 2013 | 08:55 PM
jle70's Avatar
jle70
It engages and disengages the clutch in about 40% of the pedal.
Old Dec 23, 2013 | 09:08 PM
86fsbronco's Avatar
86fsbronco
That's about right it shouldn't engaged/disengage the clutch as soon as you foot hits the pedal because in high traffic situations when taking your foot completely off the pedal would where your leg out there's supposed to be a little bit of free play in it so when you leave you foot on the pedal it won't push to hard on the throw out bearing so it won't where out prematurely
Old Dec 24, 2013 | 06:50 PM
jle70's Avatar
jle70
I should be specific. When you push pedal, it only takes about an inch or so in and clutch is fully disengaged. Way too soon I think. But I don't know how to adjust this. Bleed slave more? Is the master cylinder link adjustable? Chiltons book says nothing about clutch pedal adjustment.
Old Dec 24, 2013 | 09:25 PM
86fsbronco's Avatar
86fsbronco
Perhaps you got the wrong clutch set? I've seen it happen to a friend ha got the wrong clutch set and installed it in his truck and the clutch was way to stiff.
Most Ford clutchs look the same especially if you get one from like Advance, Napa or Autozone. What it could be is "IF" it's wrong the diaphragm on the pressure plate sticks out further than it should. Which eats up your free play and gives you a clutch that disengages to soon or is incredibly to hard to disengage.
I work at a part store I've seen a lot of parts packaged wrong. And seen people just sell people the wrong part, or sell them the right part and give them the wrong part if you can check your part numbers on your clutch the box vs the receipt vs whatever store you got it from
Old Dec 24, 2013 | 09:47 PM
jle70's Avatar
jle70
I compared the pressure plate and they matched. Prior to install. Clutch isn't stuff, just engages early.
gatorfoot
Jun 19, 2015 06:40 AM
bigcrunch
Mar 6, 2010 12:15 PM
corpse
Feb 9, 2009 07:19 AM
xc4life_nemo
Nov 9, 2006 06:38 AM
Tony G
Jul 15, 2004 01:35 AM
