paint
Old Mar 30, 2001 | 07:00 PM
postman's Avatar
postman
paint
I'm finally getting started on my 53 -f-100. It has original paint which is flaking off hood. Should I strip all old paint off or can I just sand good. If I have to strip ols paint- what method is best?
slolson@icehouse.net
Old Mar 31, 2001 | 07:21 PM
mtflat's Avatar
mtflat
paint
If you decide to strip the paint, I haven't found anything better than the Martin Senour Paint product: #6802 Water Rinseable Paint Stripper as carried by my local NAPA dealer. It is incredible - took only 3 applications and a putty knife to remove 5 layers of cured paint on my 48 F1. The paint just wrinkles up on contact - naturally, keep it away from any painted surfaces you need to protect!
Old Apr 1, 2001 | 05:02 AM
harddrive4x4's Avatar
harddrive4x4
paint
>#6802 Water Rinseable Paint Stripper as carried by my local NAPA dealer. It is incredible took
Do you know if this senour Paint stripper will remove powdercoat?
I need to refurbish some wheels with powdercoat on them. Thanks!
Mike K
Old Apr 1, 2001 | 11:36 AM
jwcnj45's Avatar
jwcnj45
paint
Powdercoat is best removed with heat. At 400* it will melt. It can be removed with a common propane torch and wire brush. I have also had good results by sanding completely and applying a good acrylic urethane paint dirrectly over it.
Old Apr 2, 2001 | 03:57 AM
harddrive4x4
paint
THANKS!!!!
Mike K
Old Apr 2, 2001 | 05:21 PM
postman's Avatar
postman
paint
Thanks mtflat. That was a great help. I can allways count on you guys to answere my questions. thanks again.
Old Apr 2, 2001 | 08:20 PM
Franklin2's Avatar
Franklin2
paint
MIKES 68 F100
155
Nov 30, 2016 10:03 AM
GM4WALLS
16
Mar 20, 2016 12:27 PM
svolpone
Aug 13, 2014 07:18 PM
damarble
Apr 16, 2014 09:23 PM
Rocking M
Paint & Bodywork
16
Apr 11, 2003 10:16 AM
