1960 Steering adjustment
Old Apr 21, 2001 | 06:38 AM
jan's Avatar
jan
Can anybody tell a laymen how to adjust the steering box to get rid of about 4" of play? Second, front cab corners, where do I go to find these.
Thanks
Old Apr 21, 2001 | 07:20 PM
fordmann's Avatar
fordmann
There is a nut with a flathead screw in the center of it. Back the nut off a little but and turn the screw in a little at a time and test drive it. This is located on your steering box. You might have to repeat this several times.
Check out Dennis carpenter online for the cab corners. I don't have the address at this time.
Fordman
Old Apr 24, 2001 | 06:02 PM
hirschi's Avatar
hirschi
The service/shop manual tells how to do it pretty clearly if you can get a hold of one. If the adjuster screw doesn't go in to far than you probably have to rebuild the steering box.
That's my 2½ cents.
James
Old Apr 26, 2001 | 10:49 PM
texasbob's Avatar
texasbob
[font size="1" color="#FF0000"]LAST EDITED ON 26-Apr-01 AT 11:51 PM (EST)[/font][p]When you get set to adjust the steering you might need to loosen the clutch slave cylinder to get to the adjuster.For the cab corners Mac's antique auto parts has a lot of stuff and only deals in Fords http://www.macsautoparts.com/ is their online catalog. I got a shop manual, parts for steering gearbox and lots of otherstuff from them.
Old Apr 28, 2001 | 06:54 AM
58f100's Avatar
58f100
one thing to add,, my steering box was very loose and i adjusted all of the play out ! BUT !!!!!! make sure the wheels are in the center position !!!!!! when making adjustment, and check all the other things ?? tie rod ends ,, kingpins for excess play.
Old Apr 28, 2001 | 06:56 AM
58f100's Avatar
58f100
i forgot,,,, check the spring shackles and the bushings too
Old Apr 28, 2001 | 05:05 PM
jan's Avatar
jan
Thanks, seems your suggested link was of some help, they say fabricate!!!!!
Old Apr 28, 2001 | 05:08 PM
jan's Avatar
jan
58F100, I have new springs, tire rod ends, tried adjustment, it helped but I need to get an offset screw driver to get to the screw. Know of any one looking for windshield seal, front and back, I purchased a pair but I need the crome groove and a wrap around rear window. Cheap !!!
Old Apr 28, 2001 | 11:02 PM
whomrig's Avatar
whomrig
ron9
Sep 29, 2007 07:04 PM
Deebo
1997 - 2003 F150
May 5, 2002 09:57 AM
yenima38
Mar 20, 2002 11:03 PM
cbpldc
Bronco II
Jul 11, 2001 07:50 AM
sparky
Dec 5, 1999 05:38 PM
