Sponsored by: Real Truck
Led signal flasher
Old Dec 18, 2006 | 05:50 PM
rwilimo's Avatar
rwilimo
Led signal flasher
I replaced my tail light bulbs with led bulbs and now have the fast flash problem as I expected. After searching I found that the Trico EP-27 flasher seems to be the correct replacement for my 04. Now the question is if I also replace my front lights with led will this the flasher still work?
Old Dec 19, 2006 | 10:12 PM
slisty's Avatar
slisty
It should.
Old Dec 19, 2006 | 10:20 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes it will.
Ordinary flashers depend on a level of resistance (or load) in the the turn signal circuit to time the flashing. The bulb is the load. This is why if you had a burned out turn signal bulb your flasher would flash twice as fast. LED bulbs do not have the same "load".
Flashers designed for use with LED bulbs are not as dependant on the bulb "load" to operate properly.
Old Dec 20, 2006 | 04:44 AM
rwilimo's Avatar
rwilimo
Thanks much!
gpeade
2004 - 2008 F150
Dec 12, 2015 09:20 AM
cbzdel
Nov 29, 2011 12:51 PM
Jaime74656
37
Jun 1, 2011 10:11 AM
'08FX4
Feb 20, 2010 11:57 AM
jaym69
2004 - 2008 F150
Jul 14, 2007 06:25 PM
