Sponsored by: Real Truck
Flasher Location
Old Feb 2, 2010 | 08:25 AM
'08FX4's Avatar
'08FX4
Flasher Location
I'm replacing the tail turn and stop lights with LED's, There is a cross reference guide on the web site for flasher replacement to stop the fast flash caused by the LED bulbs. on my '08 F-350 I am looking for the turn signal flasher location so I can pull it and swap it out... I dont have an owners manual for it... Thank you for your help ~~~Chris
Old Feb 2, 2010 | 08:43 AM
senix's Avatar
senix
Here is a link your manual from Motorcraft:
http://www.motorcraftservice.com/pub.../08f23og4e.pdf
Page 297 starts the info in Fuses/locations.
Old Feb 2, 2010 | 09:40 AM
Downriver Thunder's Avatar
Downriver Thunder
I was curious on the location as well but it gives a login error when you click on the link.
Old Feb 2, 2010 | 11:59 AM
senix's Avatar
senix
Go to Motorcraft. Then you will search by year, make and model.
Old Feb 2, 2010 | 12:22 PM
Downriver Thunder
I see where you can look up and order parts but don't see anything that will show me where the flasher is.
Old Feb 2, 2010 | 01:14 PM
senix's Avatar
senix
passenger kick panel, fuse # 6 is the turn signals. I think what you may be after is under the hood in the power distrubtion box.
Location # 34 indicates trailer stop/turn relay 25 amp fuse, think it is a mini fuse.
Old Feb 2, 2010 | 05:55 PM
pbeering's Avatar
pbeering
I don't think there is a flasher on the '08. The turn signals are controlled by the computer, which has to be reprogrammed if you change the lighting load.
Better approach is to get the replacements from someone like Recon that has a resistor installed to keep the draw where the computer thinks it should be.
Old Feb 19, 2010 | 03:19 PM
Downriver Thunder
I finally found my flasher on my 05, right through the little storage thingy to the right of the wheel.
Old Feb 20, 2010 | 11:57 AM
bill64's Avatar
bill64
08's dont have flashers, its controlled by the smart junction box (body computer) which is also the fuse box location. it has programable features to it, not sure about reprogramming flash rate though. the flasher sound you here is a tone generator in the instrument cluster
Flame Out
Electrical Systems/Wiring
Nov 22, 2016 10:17 PM
mlbmd
6.4L Power Stroke Diesel
Aug 15, 2011 10:00 AM
cgunder20
Apr 20, 2009 10:20 AM
dgmcneal
Jul 17, 2008 02:29 PM
ohheflies
1997 - 2003 F150
Feb 16, 2004 08:41 AM
