Flasher question/help
Old May 18, 2011 | 10:09 AM
Jaime74656's Avatar
Jaime74656
Ok I have a 552 flasher currently in my truck (its the green one) now I got a pair of LED bulbs which still work for the most part except for the blinking/flashing bit (figure the diodes are burnt out or somethin due to the flasher) so im wondering if anyone knows where I could find a replacement for my current flasher which is LED capable? id like to finish my LED conversion for my truck and this is the main thing i have left except for a couple festoon bulbs...
Old May 18, 2011 | 10:29 AM
Edgethis's Avatar
Edgethis
I think you need to add resistors to make the LEDs flash properly. I wasnt aware that there was a flasher with this capability.
Old May 18, 2011 | 10:41 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Sorry to go offtopic, but where can I get the flashers, like on an emergency vehicle?
Old May 18, 2011 | 12:19 PM
Jaime74656's Avatar
Jaime74656
OK first I'm NOT talking Emery vehicle flashers as this is not a topic related to turn signals. Second for that ot question lets take that to PM please. As for the flasher it still flashes and new led bulbs work fine but I am looking for a way to lessen the amps or what ever so the diode won't burn out or up anymore.
Old May 18, 2011 | 12:41 PM
Edgethis's Avatar
Edgethis
You shouldn't have any diodes burning out with a quality LED. And LEDS draw very little amps.
Sidewinder-
Sirens - Dash Lights - Grille Lights - LED Lights - Seat Organizers - Warning Lights - Vehicle Decal : Galls
Old May 18, 2011 | 01:27 PM
Jaime74656's Avatar
Jaime74656
Sidewinder-
I'm thinking too much going to the diodes but I'm not sure how to tell what is going on...
Old May 18, 2011 | 03:18 PM
F150xlt's Avatar
F150xlt
You need to use a LED flasher also called an electronic flasher.
The electronic type flasher has a electronic timer circuit that determines
the flashing rate.
The factory thermal/mechanical type flasher, flashes at a rate depending on
the circuit current load. More bulbs in the circuit the flashing rate increases.
Less load such as when you replace a incandescent bulb with a led bulb could
cause the circuit to not draw enough current so the flasher doesn't work or
flashes really slow.
Ever notice if one of the turn signal bulbs burns out the flasher stops working?
That's because the current load has changed and there isn't enough current
draw so the flasher doesn't flash until the burnt out bulb is replaced.
An electronic flasher can't detect if a bulb in the circuit is burnt out.
You can purchase a LED flasher on E-bay for about $13.00.
Here's the link for a 2 prong flasher.
LED Turn Signal Flasher NEEDED TO INSTALL ANY LED | eBay
Old May 18, 2011 | 03:22 PM
86F150302's Avatar
86F150302
Ive swapped my whole truck to LED.
You need an electronic flasher. You can get one from an auto parts store for like $10 in the electrical isle. I think I have the EL12
Old May 18, 2011 | 09:31 PM
SideWinder4.9l
Just to be sure I am on the right track, i need a flasher that will flicker on/off FAST.....Simialar to ambulances, etc....
Old May 20, 2011 | 11:45 AM
Jaime74656's Avatar
Jaime74656
Will this el12 flasher break if its used with nonled bulbs??
Old May 20, 2011 | 11:53 AM
86F150302's Avatar
86F150302
Nope will be just fine.
Old May 20, 2011 | 12:40 PM
Jaime74656's Avatar
Jaime74656
OK sweet just picked one up off eBay for me to use thanks!!
Old May 20, 2011 | 07:19 PM
Slowroll90's Avatar
Slowroll90
Electronic flashed unit
I got mine from AutoZone because my trailer lights made it hyperflash but it's the same story for LED bulbs
Old May 21, 2011 | 11:15 AM
Jaime74656's Avatar
Jaime74656
OK what color was it and number??
Old May 22, 2011 | 10:16 PM
Slowroll90's Avatar
Slowroll90
Blazer FL32
The flasher is transparent smokey grey
its a 2 pin flasher. I believe the packaging is red.
