Oil & Lubrication
Filters
Old Apr 30, 2003 | 11:31 AM
Jupiter Coyote's Avatar
Jupiter Coyote
Filters
I have heard that Fram filters are junk. Is this true?
What are the better filters?
What are some BAD filters?
What is the general consensus on STP products?
Thanks!
Old Apr 30, 2003 | 11:44 AM
rusty70f100's Avatar
rusty70f100
Filters
I think everyone on here will agree with me:
Fram = Junk
Stp = Junk, with possible use as assembly lube.
Have a nice day!
Old Apr 30, 2003 | 07:04 PM
Rockledge's Avatar
Rockledge
Filters
Jupiter, here is a link to an 'Oil Filter Study' that has some interesting info and comments on Fram and other filter brands:
http://www.minimopar.net/oilfilters.html
P.S. Welcome to Ford Truck Enthusiasts!
Old Apr 30, 2003 | 08:49 PM
Jupiter Coyote
Filters
Great Link! Thanks!
Old May 3, 2003 | 08:37 PM
boxcar_tommie22's Avatar
boxcar_tommie22
Filters
you can't beat k&n baldwin and wix oil filters the flows are far better then any other filter....k&n=12-15gpm....wix=11-13 gpm..
Old May 3, 2003 | 09:13 PM
jschira's Avatar
jschira
Filters
Flow is only one measure of filter performance. I think that K&N and Wix are good enough filters, but not just because they have good flow rates.
Old May 4, 2003 | 07:52 AM
Shannonm1's Avatar
Shannonm1
Filters
I always seen that Fram filtered such small particles out of oil. This to ment some pretty good oil restriction. Which wouldn't be good if you had a dirty engine.
Old May 4, 2003 | 08:43 AM
James Hewett's Avatar
James Hewett
Filters
I never use anything but Motorcraft Oil filters on my Fords, everytime I do I hear lifters click'n on a cold start.
on my 56, with 371C, especially, so I run a #300 Motorsraft shortyfilter and never have that click, even when the car is parked all winter.
As far as the F150, I sure the dealer would not warrenty the engine if something was to happen to it with another type filter on it.
I had the worst oilpressure even on a cheby motor I had w/Fram.
Old May 4, 2003 | 03:08 PM
Matts72's Avatar
Matts72
Filters
One time I had a Fram filter on and my oil pressure skyrocketed after about 500 miles, not because of flow but that the filter was restricting flow so badly.
Old May 4, 2003 | 04:40 PM
Cloim's Avatar
Cloim
Filters
Car warranties cannot legally be voided by the use of non-oem filters or fluids. As long as the filter/fluids meet oem specs.
And despite the dissing of Fram products, they are warranty friendly. I even used one once.
That, however, should not be construed to be an endorsement of their product.
Old May 4, 2003 | 09:20 PM
James Hewett
Filters
what I ment to say , that when I don't use Motorcraft, I hear lifter click'n on cold start.
I know yur right about refusing claim as long as it is OEM quailty, but from my way of think'n about some service writers that have to much to say about way they want to pick your pocket, they always treat customers as if your just a customer and they are smarter then you.
Old May 6, 2003 | 03:51 PM
tommowry's Avatar
tommowry
Filters
I have had similiar experiance with Fram filters. The engine gets awful noisy when I use one. Definitely check out the filter study on mini-mopar net. This is another good forum with a bunch of gear heads. The nod seems to go to purolator or one it's clones. If you are looking for good but inexpensive then check out the Tech-line at Wal-mart for 1.99 (Champ Labs; they used to make lee filters ) Napa Silver, a Wix for about 2.50, Proline from Pep-Boys ( purolator clone). Definitely check out the survey though lots of good info.
Old May 6, 2003 | 05:48 PM
2fords2's Avatar
2fords2
Filters
I think the concern over cold start up engine noise with a Fram filter is valid. Their nitrile ADV is simply too weak. I had a similar experience with my E150 van. It was so bad I darn near took it in to the dealer before I learned it might be a filter problem. Hard to beat the Motorcraft filter on a Ford.
Then I bought an Escape and read this in the owners manual: "If a replacement oil filter is used that does not meet Ford material and design specifications, start-up engine noises or knock may be experienced. It is recommended you use the appropriate Motorcraft oil filter (or another brand meeting Ford specifications) for your engine application."
That's a heck of a lot stronger statement than a bunch of guys like us venting on the internet.
Old May 7, 2003 | 09:20 PM
mikemc's Avatar
mikemc
Filters
I like using OEM filters. Motorcraft in my Ranger and AC/Delco in our Cavalier. They are good quality for the money and look great in a warranty claim.
Old May 9, 2003 | 05:11 AM
MScotty's Avatar
MScotty
Filters
Is it a "Dash"?
