Check Engine Codes
Old Dec 4, 2006 | 04:31 PM
rsmiley's Avatar
rsmiley
Check Engine Codes
Check Enging light is now on and the codes are P0174 and P0171. Does anyone know the nature of the problem of these two codes?
Thanks........
Old Dec 4, 2006 | 05:03 PM
FortyFords's Avatar
FortyFords
It means Bank 1 and bank 2 are lean acording to the o2 sensors
It can be fuel delivery or a a leak in the air induction after the maf or leak at the pcv valve hose .
Also could be intake o-rings.
Rich
Old Dec 5, 2006 | 12:39 AM
LxMan1's Avatar
LxMan1
The most common causes are either a dirty MAF or a bad elbow on the PCV hose(especially where it hooks to the back of the intake).
Old Dec 5, 2006 | 12:13 PM
LEVEL10's Avatar
LEVEL10
here is a web site with the codes listed and information on what to check .
http://www.obd-codes.com/index.php
and the link to what they say for your thrown codes
http://www.obd-codes.com/trouble_cod...gen-sensor.php
it lists all the codes for almost all the sections with a obd code,
if you have a trans code check out the code lists in out web site for what a traans code has been found to need foer the repair.
good luck man
captchas
level10power phone tech.
Old Dec 12, 2006 | 10:03 AM
rsmiley's Avatar
rsmiley
Well replaced fuel filter, PCV valve, cleaned the MAF sensor and code still there. Looks like time to change the hose from the PCV valve and elbow. Anything else worth changing before taking to the dealer?
Thanks.....
Old Dec 14, 2006 | 12:12 AM
LxMan1's Avatar
LxMan1
Not really. Just verify that there are no other vacuum leaks.
Old Dec 14, 2006 | 01:36 PM
galaxie641's Avatar
galaxie641
Did you clear the codes after that and have them return?
Old Dec 15, 2006 | 04:03 AM
rsmiley's Avatar
rsmiley
yes, and they returned the next time I turned on the ignition.
2006powerstroke90
Jul 26, 2023 09:24 AM
i eat hybrids
May 20, 2017 10:15 PM
hhcobra
Jan 2, 2010 08:53 PM
woodsman1991
Modular V10 (6.8l)
Feb 3, 2009 03:03 PM
E Hall
Oct 20, 2006 03:58 PM
