Modular V10 (6.8l)
Check engine code.
Old Feb 2, 2009 | 06:50 PM
woodsman1991's Avatar
woodsman1991
Check engine code.
I got an error code P0359. Anybody able to read this for me?
Old Feb 2, 2009 | 09:36 PM
Gofigurethis_01's Avatar
Gofigurethis_01
https://www.ford-trucks.com/article/...r_Misfire.html
Sounds like a coil problem? I have not (knock on wood) experienced this problem with my engine , but I'm sure somebody that has will come along.
Good Luck!
Old Feb 3, 2009 | 07:50 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
# P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
That's cylinder # 9. Second from the back on the driver's side.
Pull the COP and make sure there's no rust, moisture, dirt, etc. Then, reapply dielectric grease to the tip, around where the boot seals to the COP itself, and where the boot seals to the head.
If the COP is misfiring, the PCM will sometimes pick it up as a circuit malfunction.
If you clean everything up and it's still doing it, replace the COP.
Old Feb 3, 2009 | 03:03 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
When reinstalling your coil, make sure your boot slides over and fits snugly into place.
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
See your FTE special at:
https://www.ford-trucks.com/forums/793806-cop-fte-special.html#post6780133
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Bluebomber94
Nov 11, 2017 10:20 PM
i eat hybrids
May 20, 2017 10:15 PM
kbf1961
Oct 17, 2015 10:05 PM
88 250
Dec 24, 2010 04:14 PM
Miketnf150
1978 - 1996 Big Bronco
Aug 21, 2002 12:57 PM
