Codes Codes and more Codes!!!
Old Jan 2, 2010 | 05:01 PM
hhcobra's Avatar
hhcobra
I've got a 2001 7.3 Excursion that has been throwing the same codes for 18 months. The truck has never had a problem starting with temps in the 20's and not plugged in. The codes being thrown are P-0672, P-0674,P-0676,P-0678,P-0683. I've checked all conections to the GPCM and all conections to the valve covers and no corrosion and no chaffing. My question is can I damage anything or have I already damaged something by ignoring these codes. (sorry about spelling) Thanks!!!
Fred
Old Jan 2, 2010 | 05:37 PM
rtazz17's Avatar
rtazz17
Since you arent having any problems and have verified everything is working have you tried just clearing them to see what comes back?
Old Jan 2, 2010 | 05:49 PM
hhcobra's Avatar
hhcobra
Thanks for the fast response!! I cleared the codes a couple of times and they clear when the engine is warm, but when it cools off they come back.
Fred
Old Jan 2, 2010 | 06:50 PM
F350-6's Avatar
F350-6
I'd guess you've either got a bad GPCM or a short in the wiring related to the driver side. If the truck is starting fine, then you're not hurting anything other than the live of the CEL bulb.
GPCM trucks are set to throw a code with any glow plug or controller issues since it may cause more smoke.
Old Jan 2, 2010 | 07:09 PM
hhcobra's Avatar
hhcobra
If it were a bad GPCM, would it start every time without any problems in cold weather?
Fred
Old Jan 2, 2010 | 08:53 PM
F350-6's Avatar
F350-6
It might smoke more, but would probably still start. Since you're issue seems to be isolated to one side, it sounds as if at least half of your glow plugs are still working properly. With at least 4 working, that would make it start up easier.
IHdieselfan
Aug 19, 2014 07:43 PM
Cjohns79ga
Jul 1, 2013 01:39 AM
meccox
Jan 2, 2012 07:28 AM
FSeybert
Nov 14, 2011 06:54 PM
florit
1997 - 2003 F150
Oct 22, 2003 11:14 PM
