code p132
Old Oct 19, 2006 | 10:08 PM
E Hall's Avatar
E Hall
code p132>
Going on a trip and the engine light came on. I checked for codes and P132> came up. Does anyone know what it is?
Old Oct 19, 2006 | 11:48 PM
Maxium4x4's Avatar
Maxium4x4
How did you retrieve this code? No 132 exists but I am sure one of our resident techs may have an answer for you.
Old Oct 20, 2006 | 12:07 AM
E Hall's Avatar
E Hall
I couldnt find it in any of the posts or web sites. so i checked it again and the same thing. i cleared it this time. i only ran the motor for 1 min after i cleared it and nothing so far. I used an old tuner that i dont use for tuning because it got stuck on level 6 and had to have the dealer reflash.
Old Oct 20, 2006 | 12:53 AM
Cowboy Brett's Avatar
Cowboy Brett
P132?
P0132 is a code for an Oxygen Sensor fault, Bank 1 Upstream. The only problem with that possibility is that it is not in my 6.0 Shop Manual.
If that's really what it was trying to tell you, something's really messed up.
Old Oct 20, 2006 | 06:30 AM
CanadaGuy's Avatar
CanadaGuy
P132B is an early build boost code.
Old Oct 20, 2006 | 07:29 AM
03f2506.0's Avatar
03f2506.0
P0132b
P0132B was the code present when I had the 2nd turbo replaced on my '03. I had no boost/power and the vanes would grind under heavy load.
Old Oct 20, 2006 | 07:36 AM
vloney's Avatar
vloney
thats one of the new codes put in with the new reflashes that no one wanted to get. Just as a side note, the first step in the diagnostics for this code, is to check for aftermarket modifications.
Old Oct 20, 2006 | 07:59 AM
Maxium4x4's Avatar
Maxium4x4
You know me, my truck is all stock and the code would not apply....
Once again our resident techs are up to date on issues.
Old Oct 20, 2006 | 12:32 PM
vloney's Avatar
vloney
There's no codes to cover your truck!
Old Oct 20, 2006 | 03:19 PM
Maxium4x4's Avatar
Maxium4x4
what you trying to say....
Old Oct 20, 2006 | 03:58 PM
kw5413's Avatar
kw5413
Me thinks you are going to spend waaaaay to much time in the new diesel competition forum. I may have to fly solo again while my wingman is off doing tower fly-bys....
Edogsf350
Jun 7, 2016 08:54 PM
ryan044x4
Oct 26, 2014 12:56 PM
CoalRollinX
May 1, 2013 09:19 PM
PoPs 03DEX
Aug 10, 2011 04:26 PM
F250Wheels
May 1, 2008 06:21 PM
