CCV Mod / Smoke
Old Dec 2, 2006 | 04:24 PM
  #31
ryaneverk2's Avatar
ryaneverk2
Haha, yeah when I first planned on the CCV mod, I went and bout 20' of black heater hose as that's what I'd read to use... then further reading and folks suggested the clear vinyl hose, and said it'd hold up just as well. Soooo... I've got 20' of heater hose sitting in the attic. The clear is great because you can see any potential obsructions.
Old Dec 3, 2006 | 12:30 AM
  #32
jtharvey's Avatar
jtharvey
I would think that the clear would gunk up the whole way on the inside and you would see nothing but black everywhere. I'm guessing that's not the case? I recently noticed that there is some oil on the outside of the heater hose for my CCV, in the low spots, apparently oil is seeping through the hose. So, I'm looking to replace it. Maybe I should try the clear vinyl type.
Old Dec 3, 2006 | 01:43 AM
  #33
ryaneverk2's Avatar
ryaneverk2
The clear vinyl type seems to be holding up real well, Jeremy. The first few feet of it, where it first comes off the valve cover, is definitely pretty brown/black and cloudy. However, farther down the hose, it's still clear all the way, aside from the bit lining the bottom at the couple low spots.
If you replace yours, I think you should go with the clear hose.
Old Dec 3, 2006 | 03:11 AM
  #34
VQ2Fast4U's Avatar
VQ2Fast4U
I had mine coming down the back of my fuel tank near the rear axle, I changed it because I was starting to see oil in the line at 2 low spots where the hose was on the frame rail. Now it exits at the front of the fuel tank right off the frame rail. I get less smell now then when it was further away.
Old Dec 5, 2006 | 11:39 AM
  #35
Highmark18's Avatar
Highmark18
Ryan, if my vent ever does get plugged, what are the symtoms? I assume it will blow oil out the seals? Reason I ask is I seem to have developed a small "weep" coming out of the oil pan gasket, but I still have smoke out the vent. I am wondering if the weep is due to the -5 temp we had the last couple days.
Old Dec 5, 2006 | 12:35 PM
  #36
jtharvey's Avatar
jtharvey
With your truck running, pull the dipstick out. If you see the vapor being forced out of the dipstick tube at that time, then your CCV is most likely plugged. Also, check the end of the CCV hose. At idle, I've always got a little vapor coming out of it.
Old Dec 6, 2006 | 11:04 AM
  #37
Highmark18's Avatar
Highmark18
JT, I checked the dipstick tube, I do get a very small amount of vapor when I pull the stick, but I do have a good amount coming out the vent as well when idling. I assume this is normal?
Old Dec 6, 2006 | 03:13 PM
  #38
ryaneverk2's Avatar
ryaneverk2
Sounds normal.
Old Dec 6, 2006 | 09:22 PM
  #39
jtharvey's Avatar
jtharvey
I agree with Ryan, a little vapor sounds normal. If you've got a good amount still coming out the CCV when the dipstick is pulled, I think you're ok.
Old Dec 17, 2006 | 09:19 PM
  #40
hosemandc's Avatar
hosemandc
I have the Raycor Filter for my CCV and I love it. A bit expansive at first but keeps the sludge out of the turbo and no bad smells associated with othe CCV mods.
2002 F-350 4x4, Raycor CCV, ISPRO Guages, AIS Filter
Old Dec 18, 2006 | 10:52 AM
  #41
John7894's Avatar
John7894
How long have you had the Racor setup on there? We've heard that they were causing some problems when they first came out...
Old Dec 18, 2006 | 10:54 AM
  #42
John7894's Avatar
John7894
Originally Posted by strokin_it7.3
Here is how i have mine, and i have no problems with it. When i removed the elbow at Fall Brawl, i had some grey sludge (about a quarter's size) on the elbow. I guess the combination of parking outside in the rain, with no drain hole and the CCV gasses made this sludge. Now i have a drain hole.
It's perpindicular to flow, and it's working fine.
Kris,
You can go one better and grind a small slit in the front side of that small tube to allow some exhaust gas to flow "through" the small tube instead of around it only. That's how the setup is on my racecar.
Old Dec 18, 2006 | 11:36 AM
  #43
hosemandc's Avatar
hosemandc
I have had the Racor CCV3550-FRD-02 for 6 months and about 10,000 miles now. I have taken it apart a few times now to check the element. I havnt seen any problems or leaks. I am going to change the element next month with my oil change. John, what kind of problems did you hear about?
2002 F-350 4x4, Racor CCV, ISPRO Guages, AIS Filter, Banks Monster Exhaust and Power Elbow on the way thanks to Carisma Auto Parts
Old Dec 18, 2006 | 01:02 PM
  #44
lethal5point7's Avatar
lethal5point7
Mine is routed just under the driver's side door, so when I go through drive-through places the employees ask if my truck is on fire hahaha.
Old Dec 18, 2006 | 01:03 PM
  #45
John7894's Avatar
John7894
There have been a few threads on here about them not venting or performing well. I was looking into one since I don't really care to vent it under the truck and at the time I could've gotten one for cost. Maybe they've fixed the problems or the problems that were circulating around were user/installation related.
I'm sure if they're were any problems with yours they would've been seen by now with the mileage.
SANDDEMON08
6.4L Power Stroke Diesel
59
Jul 31, 2018 03:22 PM
ScaldedDog
Jan 3, 2015 08:30 PM
bigb56
Sep 29, 2014 10:16 PM
milman
63
May 6, 2014 09:30 PM
Splatts
13
Mar 23, 2014 07:25 AM
