Ccv smoke??
Old Mar 22, 2014 | 09:47 AM
Splatts's Avatar
Splatts
Ccv smoke??
I seem to bee getting a decent amount of smoke coming out of my ccv. How much is too much and is it a sign of something wrong, or goin out? Another thing I noticed when doin my VC gaskets is that my passenger side IC pipe was coated on the inside with an oily residue. Is that bad or am I just paranoid?? Thanks for the input. I got a video of the ccv smoke just need to load it.
Old Mar 22, 2014 | 09:57 AM
Splatts's Avatar
Splatts
http://youtu.be/IWLl45aGUMQ
Old Mar 22, 2014 | 10:00 AM
oldbird1965's Avatar
oldbird1965
Mine smokes too, I was wondering the same thing. My compression is a little low so I think it a sign of blow by.
Old Mar 22, 2014 | 10:06 AM
Splatts's Avatar
Splatts
Any idea about the oily residue in the passenger IC pipe. Here is a pic
Old Mar 22, 2014 | 10:17 AM
madMatador78's Avatar
madMatador78
Mine smokes like a train, I also have 362K on it too, it passes the cap test with flying colors, has great power, and runs well. I'm not too worried about it. If you put the oil cap on the fill hole upside down and it blows off of there then you've got some trouble. If it just rattles off to the side or doesn't move thats considered "acceptable"
Old Mar 22, 2014 | 10:54 AM
Splatts's Avatar
Splatts
I've 130k and mine runs great with good power. I can't remember if I tried the oil cap test in the past but what kind of trouble are we talking about here? You got me worried. Ha ha ha
Old Mar 22, 2014 | 11:07 AM
oldbird1965
Mine is 185K and I'm not worried. Just a little low on compression but then again my motor was cold when I did the compression test. At 130K, unless that motor has been abused, you should be fine.
Old Mar 22, 2014 | 11:31 AM
madMatador78
I would be curious to see some compression numbers on mine as well.
To the op, I wouldn't worry about it. Especially like Glenn said since your motor has relatively low miles. Unless it was run hard and put away wet, you should be good for manny more miles.
Old Mar 22, 2014 | 11:49 AM
Splatts's Avatar
Splatts
It was a fleet vehicle at pacific gas and electric. While I was there they did seem to have a good maintence program but how the employees used and abused the trucks is a toss up. Couldn't pass it up $6500 with only 110k miles.
Any idea why I would be getting all the oil in the IC pipe?
Old Mar 22, 2014 | 12:41 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
If your ccv isn't connected to your intake it's gotta be coming from either an oil coated air filter or your turbo.
Old Mar 22, 2014 | 02:32 PM
Leemakesmepee's Avatar
Leemakesmepee
I just did the ccv mod and noticed this as well...
Old Mar 22, 2014 | 07:22 PM
Splatts's Avatar
Splatts
That makes sense because before I did my IC and ccv mod I noticed the intake tube and boot was pretty oily. So I imagine the turbo was too.
Old Mar 22, 2014 | 08:39 PM
fordpride's Avatar
fordpride
If you done the CCV mode the oil is most likely conung from the IC
When the IC was in the SD oil from the CCV made its way into the IC and the that its on your truck the boost is pushing it out.
That's the reason you have oil in the cold side pipe and not the hot
Old Mar 23, 2014 | 07:25 AM
MOOSE_MACHINE
Originally Posted by fordpride
If you done the CCV mode the oil is most likely conung from the IC When the IC was in the SD oil from the CCV made its way into the IC and the that its on your truck the boost is pushing it out. That's the reason you have oil in the cold side pipe and not the hot
I would agree with that. Take off the turbo side pipe. Is there much if any oil there.
Bowie
Aug 3, 2010 04:41 PM
ngng
21
Nov 20, 2009 09:26 AM
surveyguy
Apr 13, 2009 03:08 PM
wycowboy
Oct 7, 2007 11:19 AM
parkland
24
Sep 23, 2007 04:13 AM
