Do I have PMR's
Old Jan 3, 2007 | 09:14 PM
  #46
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
The main killer of PMR's is excessive engine speed, and way advanced injection timing. I know a guy on here who raced a kid in a ricer and got the engine up to 3825 and then the next week or so just going down the road POP the engine let go. As long as you keep the engine under 3400 you will be OK if you aren't close to 400hp, and the tuner knows you have PMR's. I dynoed at 309 on 37's with my old chip and with 32's and the new chip im hoping im in the neighborhood of 320/650.
Old Feb 8, 2007 | 12:38 AM
  #47
dandelion's Avatar
dandelion
I didnt forget about this guys! It has been fairly crummy weather up here in Portland for the last month. I am planning on taking a look at mine this weekend. The build date on my motor is 01 Sep 00.
That and my 2 yr old son helped bring me a galss of wine and spilled it on the laptop. POOF!! Magic smoke gone.
Old Feb 8, 2007 | 09:29 AM
  #48
eric777's Avatar
eric777
Forged ?
I have not checked the date on the valve cover but the tag on the driver's door panel says jan 00 - So would't that mean that I have forged ??
Thanks
Eric
Old Feb 8, 2007 | 12:03 PM
  #49
GREGROB's Avatar
GREGROB
I disagree that excessive engine speed is the killer of PMR's.
The sole enemy of PMR's is cylinder pressure and since cylinder pressure is greatest at lower rpms, how can it be engine speed that kills them?
My engine made peak hp at 2700 rpms, compressive loads on the rod are greatest at that point, regardless of how fast I spin the engine.
What does go up as a function of rpms is tensile load, which could contribute to the failure of PMRs, but not nearly as much as cylinder pressure resulting in compressive load on the rod.
I do agree with you that advanced ignition timing is hard on them too, because that directly affects (read increases) cylinder pressure.
Just my thoughts.
Old Feb 8, 2007 | 08:05 PM
  #50
Craig64's Avatar
Craig64
I'll try to check on mine this weekend. It's an '01 that I ordered new in the fall of '00. I took delivery on 9/29/00. I checked the valve cover sticker, but the whole bottom half is torn off. Truck was built in Ky, but no idea about the engine.
-Craig-
rjrandy96
Aug 29, 2016 05:27 AM
Osmond4X4
Ford Truck Parts for Sale
Aug 8, 2016 06:22 PM
abowman
Jul 25, 2016 01:28 PM
anschutz1913
46
Apr 14, 2011 02:55 PM
PsD007.3
50
May 5, 2009 10:42 AM
