Still no start..Bad CPS?
Old Nov 23, 2006 | 08:26 AM
79man's Avatar
79man
Unhappy Still no start..Bad CPS?
My truck failed to start one evening, replaced te CPS with a Carquest part. It started and ran good enough to get home, but died several times on the way. I had a friend hook his scanner up, and got 3 codes: 1219, 1670, and 344. The 344 being the code for a bad CPS, I replaced it with another CPS from Carquest and unhooked my chip. Now it will NOT START. With the 1st new CPS, I didn't think the tach moved while cranking like it should (but at least it would run-sometimes). Now with the new CPS, the tach jumps like it should while cranking, but no start. Anyone have any ideas? I'm really close to taking it to a dealer, but it will really hurt my pride to see my truck on a trailer instead of in front of it.
BTW- Since I began having this trouble, I have changed the oil and fuel filter.
Old Nov 23, 2006 | 08:46 AM
Uzumati's Avatar
Uzumati
There have been several people including myself that have had bad results (P0344) with a carquest CPS. replaced it with an OEM from ebay and all was better.
I was getting all kinds of codes when that carquest part was in and Failing CCT tests. But it all cleared up with the OEM CPS.
There is only one test when 1219 shows without a few others that you didnot mention.
KA13 CHECK FOR INTERMITTENT SHORT TO GROUND ON THE CID CIRCUIT 817 (Y/LB)
Key off.
Install breakout box, leave PCM disconnected.
Disconnect IDM.
Check for intermittent short to ground on CID circuit.
Measure resistance on (CID) Circuit 817 (Y/LB) between PCM Test Pin 96 and ground Pins 25, 51, 76, 77, 91 and 103.
Grasp the harness close to the IDM connector. Wiggle, shake the harness while working your way back to the PCM connector, while looking for a spike on the DVOM.
If resistance falls below 10K Ohms fix the short.
If it doesnt clear the codes and see if it returns.
Old Nov 23, 2006 | 09:19 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Agreed, I've read here where one guy went through 2 Car Quest CPSs with similar issues before replacing with an OEM unit and problem solved.
Old Nov 23, 2006 | 09:22 AM
79man's Avatar
79man
Thanks for the quick reply amiller, but you are way over my head! I don't even know what a breakout box is! Is it possible that the Carquest CPS has caused all of the codes? I've got an OEM CPS on its way from ebay. I'm gonna put it in, and if that don't fix it I guess it's off to see the dealership.
Old Nov 23, 2006 | 10:41 AM
Kwikkordead's Avatar
Kwikkordead
Let's hope the OEM cps does the trick.
Old Nov 24, 2006 | 07:34 AM
The Rat 2's Avatar
The Rat 2
I had a no start problem as well...changed the cps and still wouildn't start. I then removed the power chip from the power module and it started. I had to jiggle the chip a little when I put it back on the power module, but it has been working ever since. Try removing the chip if you have one
Old Nov 24, 2006 | 08:17 AM
79man's Avatar
79man
I did remove it after I installed the 2nd CPS. No change.
Old Nov 24, 2006 | 08:40 AM
Uzumati's Avatar
Uzumati
That eliminiated the CPS and tach movement during cranking rules out wiring issue for the 344 code.
The 1219 is the most troubleing since if it is not a short in the CID circuit wire it is time for a new IDM. Do you feel comfortable Ohming out that circuit?
Old Nov 24, 2006 | 09:31 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
for those of you who need one 99-04 7.3L
F7TZ12K073A List $187.20 FTE $101.09
Ed
Old Nov 24, 2006 | 05:21 PM
Uzumati's Avatar
Uzumati
79 Here are the pinpoint test for DTC 1219 & 1670
BTW on 1219 the test start on page 4 at KA12 for the 1219 code
File Type: pdf
File Type: pdf
Old Nov 25, 2006 | 11:05 PM
79man's Avatar
79man
I haven't had a chance to test my IDM with all the family home for the holidays, amiller. But if it's bad where do you guys suggest buying a new one. Should I stick with OEM, or is there an aftermarket place you prefer. Thanks for all your help guys!
Old Nov 26, 2006 | 07:19 AM
Uzumati's Avatar
Uzumati
Dieselsite.com has them for around 530 http://www.dieselsite.com/index.asp?...S&Category=323
Old Nov 29, 2006 | 10:44 AM
79man's Avatar
79man
Gave up and decided to take my truck to a dealer. As a last effort, I got out the owners manual and pulled/checked every fuse that had anything to do with the pcm or idm. After not finding any blown fuses, I hit the key one last time ......... and to my surprise the old gal fired right up. I went ahead and took it to the dealer anyway. Long story short, he couldn't find anything wrong with it except a bad MAP sensor. He said it was registering a barometric pressure of 14 when it should have been around 29. He drove it on a 20mile round trip w/his scanner hooked, and got no codes. Any ideas?
Old Nov 29, 2006 | 11:23 AM
Uzumati's Avatar
Uzumati
14 = 29
Baro at sea level is 14.7 psi which translates to 29.92mm/hg that we are used to seing on the weather channel. Now the MAP reads the actuall pressure (in psi) in the Intake Y. Then the PCM calculates MAP - Baro (integrated into PCM) to come up with Guage Pressure (Actuall boost) psi. You can actually read all of these PID's so when he says the MAP is bad because the Baro is 14 I gota ?? to make sure he is just not trying to sell you a part.
Old Nov 29, 2006 | 01:07 PM
79man's Avatar
79man
No, I'm not gonna replace it. He thinks maybe my chip has went bad. I'm gonna drive it for a few days and see how it does. If it seems fine, I'll try hooking the chip back up. Thanks for all your help!
strokin'_tatsch
228
Feb 7, 2026 07:00 AM
duggyb
15
Mar 8, 2016 07:45 AM
magnumak1
Feb 1, 2012 11:39 AM
rosa70
Jul 10, 2007 05:19 PM
dirttoo
16
Sep 12, 2006 07:24 AM
