Gear oil
Old Feb 18, 2012 | 05:18 PM
rangergirl94's Avatar
rangergirl94
Gear oil
I just picked up 3.54 ls front diff do I need ls additive to the gear oil like the rear. Is there any other precautions I should take?
Old Feb 18, 2012 | 06:21 PM
popupJunky's Avatar
popupJunky
Yes you need oil with friction modifier. You can usually buy just the additive or some oils out there have it. It will say it has limited slip additive. Without it you will burnout the clutches really quickly
Old Feb 18, 2012 | 06:46 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Yes, valvoline used to have friction modifier in it's durablend, but If you don't use friction modifier your clutches will chatter and probably not last real long. I prefer ford's oil and adding the additive, but any high grade gear lube will be fine. In a ranger you shouldn't have the loads or the heat that a big 1 ton makes so conventional oil be fine.
Old Feb 18, 2012 | 07:45 PM
rangergirl94
Will lucus work the bottle says good for ls?
Old Feb 18, 2012 | 07:51 PM
kd0axs's Avatar
kd0axs
Are you sure it's a LS diff? They never put LS in front axles, so unless someone had swapped it out for LS, it's a regular open diff.
Old Feb 18, 2012 | 08:06 PM
rangergirl94
The axle code was h9b I looked it up it said ls. Another question can I take just the gears out of the diff and put them in a d 44 solid axle? Out of a 79
Old Feb 18, 2012 | 08:15 PM
Encho's Avatar
Encho
The Southernmost Mod
If you're speaking of putting the TTB 44 gears in a Dana 44 solid, yes, you should have no trouble, they should be the same, but remember to swap both ring and pinion if you do.
Old Feb 18, 2012 | 08:16 PM
kd0axs's Avatar
kd0axs
Ok, I guess I was wrong. I looked up that code and it does indeed show that both front and rear axles are LS. I had never even heard of that one before. It's generally not considered to be a good idea to have LS in the front because it can make steering unpredictable.
Old Feb 18, 2012 | 09:16 PM
GNR22's Avatar
GNR22
I can confirm that LS in the front makes steering unpredictable. In 4x4 on the road if you turn with LS it may want to just keep pushing you instead of turning.
Old Feb 18, 2012 | 09:33 PM
F-250 WARHORSE
Yes driveability suffers but if your LS isn't too tight it should let you corner. A factory unit shouldn't be that tight, like a trac loc or a powr lok, but I rebiult A f250 trac lok in a jeep wrangler from a 78 f250 in the rear when we did the axle swap ant that thing was tight, real tight with stock spring and clutches.
Old Feb 19, 2012 | 12:53 AM
popupJunky's Avatar
popupJunky
Yes the lucas stuff should work if it says it has ls additives. Then just use a 75-90 or depending how south you are 75-140 wouldnt hurt if you ever gonna use 4x4 for long periods
66with352
1997 - 2003 F150
Nov 28, 2016 11:16 PM
renoduckman
May 6, 2012 03:31 PM
RobS10
Oct 24, 2007 10:25 AM
smallblock351w
Oil & Lubrication
Jun 26, 2006 09:29 AM
smallblock351w
Offroad & 4x4
Jun 11, 2006 08:07 PM
