Fe Engine Id
Old Nov 10, 2006 | 05:25 PM
scottie2hottie's Avatar
scottie2hottie
Question Fe Engine Id
Ok fellas- i was told this truck i just bought was a 352, BUT it appears to be a factory 4bbl. As far as I can tell thru a little research 352's did not come in 75 3/4 ton trucks, and 352's were not 4bbl from the factory. Any help? VIN is F26YNX20245
Old Nov 10, 2006 | 05:29 PM
scottie2hottie
well just found it, per the vin that truck should be 360 2bbl. so. any 352s ever come as a 4bbl?
Old Nov 10, 2006 | 11:00 PM
Dustin1690's Avatar
Dustin1690
Well im not sure if 352 came with 4bbl but i agree your engine should be a 360 or a 390 they never made 352's at all during those years unless somebody swapped em out
Old Nov 10, 2006 | 11:03 PM
fellro86's Avatar
fellro86
Yes, some did come out as 4 barrel, but not in that year... the 360 and 390 were the newer versions of the 352. The side of the block has a 352 cast into it, since it was the original casting. I had a 64 Galaxy 500 that had a 352 4 barrel Holley factory.
Old Nov 10, 2006 | 11:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
352 engined 1958 thru 1964 passenger cars came with a 4V (optional on some years)...the 352 (1965-67) and 360 (1968-76) trucks were all 2V's.
Old Nov 11, 2006 | 12:36 AM
Thomasm67's Avatar
Thomasm67
Most later F250's upto 76 had 360's in them when they were wore out most people replaced them with a 390 or they rebuilt the 360 and put a 4barrel on it.
Old Nov 11, 2006 | 06:04 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved enjoy.
Old Nov 11, 2006 | 07:34 AM
baddad457's Avatar
baddad457
After thirty years, there's no telling what your 75 has in it now. Only checking the bore and stroke will tell for certain what it is unless you've lucked out and someone stuck a 427 in there.
Old Nov 11, 2006 | 09:57 AM
scottie2hottie
Hey that would make my day- I only paid $400 for the truck, it's a factory highboy with divorced 205 and everything works, drove it home. The truck is very powerful, I can tell you that.
Old Nov 11, 2006 | 03:25 PM
Thomasm67's Avatar
Thomasm67
Unless someone went to alot of time and money to switch from an FE to something else it's probly a 390 which is what was in my 76 Hiboy.
BigMikeUGA
59
Oct 25, 2015 06:11 PM
66f-100
Jan 15, 2009 06:08 AM
65f100_352
May 4, 2007 07:46 AM
GolferSA
Sep 3, 2003 04:50 PM
caseyatthebat1
Feb 2, 2002 12:19 AM
