bouncy speedo and surging
Old Nov 9, 2006 | 07:06 PM
oldblue31's Avatar
oldblue31
my speedo bounces and you can feel the truck surging.tach stays pretty much steady.I have also notices fuel in the valley but do not know if it is related.Anybody have any ideas?
Old Nov 9, 2006 | 09:01 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Fuel leak is most likely unrelated. Try replacing the speed sensor in the rear differential for the speedo problem.
Old Nov 9, 2006 | 09:06 PM
oldblue31's Avatar
oldblue31
can the speed sensor cause the hesitation or surging?
Old Nov 9, 2006 | 10:55 PM
DaBigTow's Avatar
DaBigTow
is it surging while the cruise control is active? that's a sign of a bad PSOM (programmable speedometer/odometer module). Ford wants about $600 for a new one.
Old Nov 10, 2006 | 06:50 AM
oldblue31's Avatar
oldblue31
I will have to check it out .I don't use the cruise much so I will today and get back to ya on it.
Old Nov 10, 2006 | 04:21 PM
Cuda_jim's Avatar
Cuda_jim
Vss in the rear diff may have metal shaving on it. Clean off the crud and re-install. It's on the top of the gear case.
Old Nov 11, 2006 | 09:57 PM
oldblue31's Avatar
oldblue31
I have not pulled it yet but it does bounce on cruise control too.Can a bad vss make the truck surge?
Old Nov 12, 2006 | 08:36 AM
DaBigTow's Avatar
DaBigTow
it'll surge on the cruise. mine doesn't surge unless cruise is on, then it's obvious
Old Nov 12, 2006 | 07:20 PM
oldblue31's Avatar
oldblue31
I replaced the vss on the rear diff and it made no difference. one auto parts store tried selling me one that goes in the tranny but i guess that is for a different year.
Old Nov 13, 2006 | 09:06 PM
oldblue31's Avatar
oldblue31
I have a tymar intake on this truck with a small chip.will that cause my truck to surge having so much air and not so much fuel?
Old Oct 12, 2008 | 03:17 PM
4x4 factory's Avatar
4x4 factory
Mine having the same problems, My VSS is new most likely the PSOM. I was hoping something less costly..Like a throttle sensor.
Old Oct 12, 2008 | 03:28 PM
colorado solar guy's Avatar
colorado solar guy
I had bouncy speedo but no other symptoms. It was the PSOM. The module is a component of the cluster. Believe it or not the PSOM from a gas will interchange into the diesel cluster. 94-97 PSOM are the same but clusters are different. The PSOM does hold the mileage so a used unit will register the prior vehicles mileage. I checked on having it repaired about $100-200 most places. I wound up buying an entire cluster from a gas job (it was cheaper) and swapped in the PSOM.
Ron Stauffer
Montrose CO
Old Oct 13, 2008 | 05:23 AM
4x4 factory
I saw on here that the is newer version of the cluster anyone know about that. And Colorado guy I used to live in Montrose.
Hughesjr84
Feb 7, 2014 08:13 PM
xcite
May 14, 2012 09:11 AM
oldblue31
17
May 27, 2007 10:30 PM
bren7176
Feb 19, 2006 11:02 PM
ttaylor530
Dec 22, 2005 05:19 PM
