AAaarrrgghhh!! Speedo STILL bouncing
Old May 24, 2007 | 06:37 PM
oldblue31's Avatar
oldblue31
I have tried a different used cluster and several; different vss sensors and my speedo still bounces and I have a slight constant surge.Any of the new vss sensors I have tried make the speedo bounce much worse.I have looked at the exciter ring and all appears fine.Could this be a problem with anything else on the engine?
Old May 24, 2007 | 06:44 PM
powerstroked162's Avatar
powerstroked162
Check your fuse box for some blown units perhaps.
Cowboy Steve
Old May 24, 2007 | 07:05 PM
tjbeggs's Avatar
tjbeggs
It probably time to change the tone wheel. I put in a limited slip carrier in my truck last week and used a different tone wheel. I now have a slight surge using cruise control. new sensor didn't help so now I need to take it back out pop the ring gear off and put the other (original) tone wheel on. Probably what you need to do also.
Old May 24, 2007 | 07:06 PM
tjbeggs's Avatar
tjbeggs
oh but before you do that yout need to closely inspect the wiring coming down to the sensor. it could have a bad spot or chaffed.
Old May 24, 2007 | 08:03 PM
oldblue31's Avatar
oldblue31
Do the rings wear out?I checked and it seems to look good.The wiring is also good.
Old May 24, 2007 | 08:09 PM
powerstroked162
Did you check any fuses?
Cowboy Steve
Old May 24, 2007 | 08:17 PM
tjbeggs's Avatar
tjbeggs
no the rings don't ear out and only have issue if they get hit with something or the bearings are loose. I have heard there is an updated PSOM (programmable speedo/odo module) that handles the variations in the signal better. Do you know when you replaced the instustment cluster if you got an updated one?
More than likely if you tone wheel looks good its not the issue.
Old May 24, 2007 | 09:32 PM
oldblue31's Avatar
oldblue31
the fuses are all good. I doubt that the cluster was the newer one.
Old May 24, 2007 | 10:49 PM
skittlejr's Avatar
skittlejr
check wiring real good. i'm thinking it might be rubbed through somewhere. check the firmness of the plug. is it seating good in the sensor. i know those tabs that go on the ears on the sensor like to break of or not bend back to there original position after unplugging it. i had a problem when it would rain or snow and the plug got wet the speedo and tranny would act up. i unplugged it cleaned it out put some grease in there. and siliconed the plug after putting it on. it'll be crappy next time i gotta deal with it (the silicone) but it's fine now.
Old May 25, 2007 | 01:11 PM
yukonsly's Avatar
yukonsly
Which fuse would have to be check? I bought a new Sensor and will be putting it in this weekend...but want to look at all the system....under hood...or under dash?...which number ...does anybody know?
Sylvain
Old May 25, 2007 | 04:57 PM
tjbeggs's Avatar
tjbeggs
pretty much check them all! there are a large number of fuses that are involved in the trasmission/speedo.
Old May 25, 2007 | 05:02 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Is the PSOM replaceable seperately? If a new VSS exacerbates the problem then couldn't the problem be the interpretation of the signal, and not the signal itself?
Old May 25, 2007 | 06:39 PM
oldblue31's Avatar
oldblue31
The problem with my speedo needle usually does not show up until around 40 mph or so then the needle does kind of a soft bouce back and forth for a difference of about 5 mph on the guage.
Old May 26, 2007 | 04:03 PM
oldblue31's Avatar
oldblue31
I checked all the wires and fuses and everything is good.I also performed a test on the speedo and the codes I got were E 08 5 and then 904 CAL when I hit the reset button again.I also cleaned the filter on the fpr and checked the fuel pressure at idle. 45 psi.What else could it be?
Old May 27, 2007 | 11:48 AM
RubberDuck's Avatar
RubberDuck
Tim, I can't remember, is the tone ring easy to change? My flip truck has a chewed up tone ring and the speedo bounces like crazy. Price? Part #?
