Speedo Surging in Overdrive only
Old May 13, 2012 | 08:17 PM
xcite's Avatar
xcite
I have been working on my 94 F350 E4OD and have fixed all issues dealing with trans and torque convertor. Truck is shifting good and new torque convertor is solid.
After getting everything working I was out driving the truck and noticed the speedo surging at speeds around 55-60. I checked speed sensor and repaced it with a know good one and still the same thing happened. Then while on the test drive I took it out of overdrive and speedo settled right out cruise worked as it should. Put it back into overdrive surging comes back cruise surges with it. Tack is working perfectly steedy. I am seaching thru my trouble shooting but havent ran into anything like this before havent decided what to check next.
Old May 14, 2012 | 09:07 AM
fuzzy1626's Avatar
fuzzy1626
When it surges, does the tack change rpms even slightly?
Old May 14, 2012 | 09:11 AM
xcite's Avatar
xcite
No the tach holds nice and steady, watched this very carefully and checked several times.
So far my next step in my mind is to clean and check all grounds ect.
It is always so much fun having oddball problems like this to find. Hopefully I will get some time this afternoon to check it further.
top213
May 4, 2024 02:40 PM
JYost17
Dec 20, 2018 07:19 PM
tom bean
Aerostar
Apr 23, 2018 11:53 PM
Ty Reedy
1978 - 1996 Big Bronco
Sep 20, 2015 11:59 PM
Fatcatpaddy
Jul 5, 2011 05:52 PM
