ABS light on
Old Nov 8, 2006 | 12:03 PM
wreakhavoc's Avatar
wreakhavoc
ABS light on
The ABS indicator light on the dash has been remaining on the last couple of days. Brakes are working fine. Any ideas?
Old Nov 8, 2006 | 06:09 PM
RACERX7775's Avatar
RACERX7775
Smile
just because the abs light is on does not mean anything is wrong with the brakes. you will need to determine which sensor is throwing the code. then repair as necessary. oh, when the abs light is on, the system will not operate.
"oh, had to say"it's my 1000th post" yay...
Old Nov 8, 2006 | 06:27 PM
wreakhavoc's Avatar
wreakhavoc
How do you go about finding the sensor etc?
Old Nov 9, 2006 | 12:15 AM
RACERX7775's Avatar
RACERX7775
you will have to hook it up to a scanner to find the code. i think there are 3. 1 on each front hub. and 1 on the rear diff. if you dont have a scanner, you might want to try and remove and clean the rear diff sensor. after you do it, you have to drive it over 10 mph and the light should go out. if not its one of the front sensors. i'm not sure if the front sensors are offered seperately. i just replaced both front hub bearing assemblies on my X and the sensors came with the new hub.
BillU05
1997 - 2003 F150
16
Sep 6, 2005 12:25 PM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
RobertGordon
Mar 6, 2004 08:22 PM
haroutd
Jan 2, 2003 08:19 PM
garymulins
1978 - 1996 Big Bronco
15
Nov 30, 2002 10:38 PM
